  • Replies 51
OMFG!!!
I Park there all the time :P
I really really FORT it was safe, the white R32 put me off but i thought it would of gotten better, so i didn't really worry, but now hearing this?
I DON"T F**CKIN think so......Im paranoid as F**K bout my R now.......and before i was just paranoid :)
Insured, Quicktrack wat else can i get? .....
What about Wetherill Park movies?
OMFG!!!
I Park there all the time :D
I DON"T F**CKIN think so......Im paranoid as F**K bout my R now.......and before i was just paranoid :D
Wetherill Park , you gota be kidding dood thats the hunting grounds for thieves of all postcodes
OMFG!!!
I Park there all the time :cheers:
we can swap skylines if you ever wanna park it anywhere :)
it should be the only City in the world where the punishment for Theft should be
DEATH
no trial, no plea's. if you are caught with stolen stuff, caught stealing something. straight up. but thats just me...
How do we get you into our judicial system :D:D:D Cause our current judges suck big time
I have to also agree that if we cant kill these low life scum bags that their hands should be removed... woudl certainly be a fate worse than death.
some scum were trying to do the same thing to my neighbour's monaro (and as much as I'd love to see it crippled) while I was playin PS2 havin jus come home from work (at 1am), luckily they weren't pros they were jus 18yr old kids. I put my front porch lights on n one of the other neighbours had foned the cops and they arrived pretty quickly... wierd thing was my car was parked right next to it too, yet they went for monaro rims instead of mine... i've got no locknut either...
anyone know if there's a bounty on monaro rims?
one of my mates had the brilliant idea of hooking up a motion detector and a camera to a portable VCR in his car (still tryin to figure out how he did it)... problem was thieves stole the VCR... there goes taht idea.
hahah havnt you people realised yet, there is no safe place to park in sydney at all, if you have a sexy car, trust me dont leave it anywhere, and if you havea arage make sure you have it alarmed casue after i heard that my friends walkie got stolen from her garage, and laser cut the hinges off the doors, just to steal it,and moving a excel that was parked in front of the garage then you know that if someone wants to steal your car they gonna do what they have to to take it off your hands...
NOTE TO SELF ; Motion sensor in Garage rigged up to buzzer in bedroom w/ Baseball bat at
bedroom door.
:headshot: F@#$%NG low scumbags
na a insident happened to my mate the other dayhis r31 (fat sound system ) parked near tram station at glenelg , like people evrywhere these dicks in a xf broke into his car with the alarm blaring ripped the **** outa his car took evrything and sum old lady waited for him to cum back cause she got no plates he rang cops and gave them no plate but was a stolen viechal aswell he lost evrything
    • hey OP can you remind me what the actual question was, I got sidetracked at V12. Do you have an turbo oil return leak and an unidentified coolant leak? The factory oil returns are terrible design; short, rubber and expensive to replace. They are very common to fail and a pain to replace because they are so short. Still, they are available new if you want to replace both last time I checked. For the coolant leak, any competent mechanic should be able to do a pressure test; that should show up where the leak is. It is almost certainly one of the billion 30 year old rubber lines which are now brittle as hell, you engine will be fine.
    • From the OP's description, sounds to me like the TCU is in 'limp home' mode --- that is, no actuation power to shift solenoids, and the EPC valve is shut (full line pressure). This effectively sticks the box in 3rd gear, with as much line pressure as possible, to try hold the high clutch clamped shut....and so you get woeful acceleration and don't feel any shifts (because they're not happening). If you don't have Consult or some other scanner to interrogate the TCU itself, you can test with a multimeter to see if it's in limp home mode....ie; stick it in D with engine at idle (hold vehicle with hand/foot brake), and measure the voltage at the TCU feeding shift solenoids A & B -- both should be ON (battery voltage). If they are energized at the TCU, you can unplug the harness from the TCU, and check resistance down through the wiring to the solenoids themselves -- you should see about 20ohms on each coil --- if you do, you can presume the wiring to shift solenoids is OK -- if both measure open circuit, you have to check intermediate connectors in the loom down to the gearbox (and the gearbox connector itself), and check the shift solenoid resistance at the gearbox connector itself --- if the shift solenoids test open circuit here, problem is in the box (ether the solenoids or wiring to them is bad). If you get no voltage at TCU connector for the shift solenoids (and the solenoids/wiring test OK), check powers/grounds to the TCU itself --- if they're ok, it suggests the TCU is the culprit (and you'd need to interrogate it if possible, to find out why it's behaving badly)...
    • Hey mate give Autotechnica a go, I recently got some Comfort PUs and rails from them, they're comfy and look great highly recommended! https://www.autotecnica.com.au/part-finder/nissan/skyline/r32/
    • Honestly, for a daily I would gladly rock a Camry. The more disposable the better. People drive horribly out here and road conditions are awful.
    • Verify it's going into each of the 4 gears in normal acceleration, make sure the torque converter locks up over ~65-70 kph or so at low throttle opening. If you ease into the throttle at those speeds eventually you should get a "gear" between 3rd unlocked and 4th locked. It should downshift eventually if you floor it at 65 kph too. Get some Matic D ATF and drain the pan, check for signs of sadness in fluid and drain plug magnet. Top off to the correct level afterwards. If the transmission is worth saving you can drop the pan on a second drain and change the filter while you're at it. These are not complicated transmissions, at least compared to modern stuff.
