Monaro found on bricks Westfield shops Liverpool
Does anyone know if the cars came with a factory undercoating?
Did that stuff come from the factory? I wasn't sure if the undercoating was sprayed afterwards to hide the rust.
I found two used throttle bodies both claiming to be from a R33 RB25DET, I bought both, when one showed up it has a large center rod with a flat side for the center drive of the TPS. The other has a much smaller center rod with a smaller cross rod through it making a "X".....this style matches what my rb25det neo engine has, so I will be able to use this throttle body and my org wiring and reuse the sensor itself. I don't know why the other has the other version (both said TB from S2) but no matter I was glad I ordered both, as I found one that will work nicely.
All of that material you found hard to remove is hard to remove for a reason. If the factory could get away with using paint I'm sure they would. If I was doing the repair, I'd be looking to replace the sealant I had just removed with something equitant or better. -
its not really a truck bed liner
