  • Replies 90
well its alll good
i put the flush in and ran the car
the ticking stopped and i took the oil out and replaced the filter and put a additive as well as new oil in it so it will clean out the bore and its fine nw
im so fkn happy its driving fine and like nothing happened
thanks for the posts guys it was informative and funny at times
have a mad xmas
well its alll good
have a mad xmas
What flush did you put in the car? There is nothing you can put in your engine that will melt/disolve porcilain...
If it's stopped ticking... dosn't mean it's fine.
FFS! at very least get a compression test done.
Paying someone to look at it is relativly cheap. Best case- you pay someone a couple hundred bucks get a compression test and to put a scope in and check it out. Worst case- you dive it around till it it destroys the head, bore, piston... then little bits of piston/bore/valve do get into the oil and get sucked through the engine. Total loss.
$200 or $4000 ???
Get the fattest piece of hose you can get through the plug hole and still wiggle around, tape one end of the hose to the most powerfull vacuum cleaner you can find hose , empty the vac before you start so you can see what you've managed to get out , now , shove the taped on hose down the plug hole n start vac'n and wigglin .
  • 4 weeks later...
When I changed my spark plugs the other day I noticed the spark plug from cylinder 6 had some porclin from around the tip broken off.... not sure when this happened but im guessing it happened when i accidently boosted it to 1.6bar a few weeks earlier.... I was in second and saw the needle go past 1.5 n backed off straight away n i think it detonated which in turn caused the plug to break :P
Im guessing the damage has already been done :D
anyone else have this problem?
detonation from overboost wouldnt break a spark plug.. they break either from force, or from excessive heat then force.
in other words you smash them with a tool or something, which is alot easier to do when theyve been baked.
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
