I don't really get the tempetyres?!?! but I don't plan to invest lot of money on that car. Especially not on rims, no go on brand like Volk Racing...
But I'm going to get something like that:
( TE replica ) with some Yokohama S.Drive :)
I do plan to hit the track, so far I'm set on 18 x 9.0 + 30 allaround
But waiting for the car before deciding on anything, should pick it up my R33 tomorrow. :D
I had Yokohama S-Drive all round on my R33, and have gone to Potenza RE001. The Bridgestones are a far better tire. Depends on the cost and what you want to spend of course though :D
I had Yokohama S-Drive all round on my R33, and have gone to Potenza RE001. The Bridgestones are a far better tire. Depends on the cost and what you want to spend of course though :)
Of course the Potenza RE001 will be far superior :P .
But like I said, it will be just for cruising around and go to work ;)
While on topic, any one running 18x9 +25 on the rear? How does it sit, any gaurd work needed? 18x9 +30 fit GTST's no problem (stock GTR wheels), so +25 should still be fine right?
will be fine it will be exactly 5mm further out the the 18x9 +30 so just work off your knowledge of how that looked and add 5 mm :D
and pls dont buy copy rims im all for cheap wheels but slapping cheap look alikes is lame its like wearing 4 stripe tracksuit pants.. everyone knows your a tightass.
atm it has 18 x 8.5 +30 w 235/40/18 nitto NT05 and 18 x 9.5 +30 w 245/40/18 nitto NT05
but in a week or 2 it will be the same rims in 18 x 9.5 +25 all round with the same tyres
cops pulled up over on an sau mt buller overnight cruise, was a top bloke.
  • 3 weeks later...
Small update, since I can't find the right type of rims or size I want (without spending to much on brand name)
I end up on DTM/Diezel Drift, they look ok.
size will be:
17x9.0 +35 front
17x10 +35 Rear
hope it will fit fine.
Edited by Mevo
  • 4 years later...
It will fit but it will hit the top arm on close to lock and at track or hard cornering it may rub on the guard...
Clean up the top arm a tad to prevent it hitting and pump front guard a tad...
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
