Also the non-turbo R34 has vvt (compared to the non-turbo R33 and R32), I find the powerband is wider, therefore you don't need to flog it as hard when driving it around town. I suppose the advantage of owning any skyline is the large number of braking and handling mods.
You are talking about VCT(variable cam timing).no RB engines have VVT(variable valve timing).
Also non-turbo R33s had VCT as well, its just set different on 34s.
Doesn't negate body style but afaik ER34 is turbo,EN34 is non turbo and at a guess HR34 could be the RB20 model.
Nup - Mine is an ER34. Sedan, non-turbo 2.5.
I "think" the
R/N mean if it's RWD/AWD
E/H mean it Sedan/Coupe
Of course I could be totally wrong.
They are essentially the "same" thing they both alter the valve timing. Reason being the camshafts drive the valves, so by altering the cam timing you are altering the valve timing....
But in saying that since this is a Skyline (Nissan) forum VCT is the more appropriate term :)
I "think" the
Alright I've got it. ER34 is rwd and ENR34 is awd. doesn't matter on turbo or body style.
  • 1 year later...
The sadan suspension has a rear nuckel . And rear has a bolt bracket type the font s Same. Iv got a lot of suspension mods on my car its good fun just need an LSD on the sadan mole
I currently own a 1994 IMPUL R33-R, #103 , SEDAN 5 SPD, i jusst bought a 1998 r34 sedan gt-t auto.
i want to know what parts are interchangeable. these are curretly installed on the impul r33-r and impul parts mostly
hks intake filter,
exhaust (change the hangers),
rims(impul rs 17x8+35, 17x9+38),
sway bars,
front strut bar
front and rear seats,
steering wheel (913 clasonic with hub)
, ash tray
, brake pads rotors,
brake lines (doluck ss)
plus the blitz dsbc, hks turbo timer, greddy boost gauge, aem wideband (these are pretty generic so im sure about these)
so what it the same as a the gts25t (impul) sedan /r34 gtt sedan, whats different and what just needs a minor fab work?
  • 5 months later...
what do people think of the non turbo version?
im on my p's and im really interested in the non turbo version, but people say its a complete hunk of junk.
i want to know the opinions of the skyline community.
also ive asked around and people think that its a hideous car?
i just bought mine and theyre not bad at all mate
  • 3 weeks later...
My sedan has an LSD :-) On the GTX-turbo - including 4 door - it was standard ie http://english.auto.vl.ru/catalog/nissan/skyline/1998_5/21632/
  • 2 years later...
All I gotta say if you like it go for it. I bought mine on my P plates drive it for 6 years gradually modifying it really fun car on Rails and now it's got a built Rb 2630. If you by one fist mods to get ls1 coils convention and Stelth automotive fuel pump.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
