Im thinking about putting either r33 or r34 gtr wheels on my r31, but i really want to check that they dont rub on my struts at the front before i shell out and so i wondering if anyone would be kind enough to lend me one or pref a pair, even pair of 32gtr would be fine. In fact anything that is the same offset would be just fine. We can come to some sort of remuneration agreement if need be!
Antz
https://www.sau.com.au/forums/topic/300695-gtr-wheels/
I've got some 32 GTR wheels I can lend you for a couple of hours.
Just a quick note, 32, 33, 34 wheels have similar offsetts but they are different widths and diameter's (16x8, 17x9, 18x9.5 I think but don't quote me) and from 31 experience, any tyre wider than 225 scrubs pretty bad. And how are you going to test fit them on a 4 stud hub
https://www.sau.com.au/forums/topic/300695-gtr-wheels/#findComment-4996206
that would be ideal, but getting my hands on any gtr wheels to test fit is rather difficult.
If you want to try and fit the wheels at my place today say 2.30pm onwards in Kambah, you can try mine.
Call me at work 6213 7760 or PM me after about 1.30pm
https://www.sau.com.au/forums/topic/300695-gtr-wheels/#findComment-5002763
hey mate thanks for the offer, but i have to do it at home, when i put on the 5 stud front hubs it wont be driving anywhere until i get a full set of wheels. hope that makes sense. But offer is much appreciated. Maybe we can organize something in the new year to test fit them, but it would need to be at my place thats all.
Cheers
Antz
https://www.sau.com.au/forums/topic/300695-gtr-wheels/#findComment-5003092
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
