  • Replies 169
once again it was good to catch up.... i know ive been slack in the meeting up department :/
good to see some new faces. have a good new year an ill see you in twenty ten
from the guy '' how did he fit those rims under thos guards '' S14
BOOM!!!
Hey guys, haven't had the chance to post till now.. Awesome cruise, lookin forward to more in the future. And I don't know if u guys realized but I had to leave without saying goodbye cuz I had an urgent call from the misses on the way to chinabar and had to take a left turn on to the freeway. Anyway it was nice meetn u all. C youz next time!
Heh i just drove down there to check
Open untill
5:30 Mon, Tues, Wed Fri?
9:00 Thurs
6:30 Sat ?
Closed Sunday
Monday 9am til 8.30
Tuesday 9am til 8.30pm
wednesday 9am til 8.30pm
thursday 9am til 9pm
friday 9am til 10pm
saturday 9am til 10pm
sunday close
thats the cafe's hours.
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
