Car was bought 2 years ago as a weekend car, rarely driven. Jap Import. Sat in the garage for 6 months at one point. Just need to sell it as it is sitting in garage. Only 64,000 on odometer.
----Mods-----
-HKS drag intercooler
-Oil Catch Can
-Oil cooler with oil filter relocation
-hi flow twin turbos
-Pod filters
-Twin Plate Clutch with flywheel
-Camshafts and cam gears (highest you can get im told)
- Racing harness for seats
-Hi flow fuel pump
-Blitz Electronic Boost Control
-Turbo Timer
-Greddy Boost Gauge
-Larger Brembo Brakes with oversized slotted rotors
-Ohlin Coilovers
- 3.5inch exhaust system from turbo back
-20inch x 10 deep dish wheels brand new
-Twin plumback BOVs
-Gearbox has also been modified for greater strength
-Large aftermarket injectors
I am also told it has forged pistons and rods.
1 year rego. (expire 9-9-10)
The car made 255kw (have dyno papers to prove) at the wheels on 14psi at Advan Performance which speaks for itself in regards to potential.
Car has been previously damaged on the back quarter panel. I have all the paperwork to prove each step of the repairs which took place, including forms of newly ordered parts.
All inspections welcome from mechanics to inspect mods and anything else. The parts alone which came on the car from previous owner are valued more than the car itself. Anyone who knows about mods will be able to tell by looking at the car and just hearing the way it sounds. Car is definitly built for track and high performance.
Asking Price $19,900K
Big Head turner. Car is not for feint hearted. Price of car negotiable, however not too much.
Edited by Nightcrawler
https://www.sau.com.au/forums/topic/300743-gtr-v-spec-jap-import-1995/
Guest
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
