Car was bought 2 years ago as a weekend car, rarely driven. Jap Import. Sat in the garage for 6 months at one point. Just need to sell it as it is sitting in garage. Only 64,000 on odometer.
----Mods-----
-HKS drag intercooler
-Oil Catch Can
-Oil cooler with oil filter relocation
-hi flow twin turbos
-Pod filters
-Twin Plate Clutch with flywheel
-Camshafts and cam gears (highest you can get im told)
- Racing harness for seats
-Hi flow fuel pump
-Blitz Electronic Boost Control
-Turbo Timer
-Greddy Boost Gauge
-Larger Brembo Brakes with oversized slotted rotors
-Ohlin Coilovers
- 3.5inch exhaust system from turbo back
-20inch x 10 deep dish wheels brand new
-Twin plumback BOVs
-Gearbox has also been modified for greater strength
-Large aftermarket injectors
I am also told it has forged pistons and rods.
1 year rego. (expire 9-9-10)
The car made 255kw (have dyno papers to prove) at the wheels on 14psi at Advan Performance which speaks for itself in regards to potential.
Car has been previously damaged on the back quarter panel. I have all the paperwork to prove each step of the repairs which took place, including forms of newly ordered parts.
All inspections welcome from mechanics to inspect mods and anything else. The parts alone which came on the car from previous owner are valued more than the car itself. Anyone who knows about mods will be able to tell by looking at the car and just hearing the way it sounds. Car is definitly built for track and high performance.
Asking Price $19,900K
Big Head turner. Car is not for feint hearted. Price of car negotiable, however not too much.
Edited by Nightcrawler
https://www.sau.com.au/forums/topic/300743-gtr-v-spec-jap-import-1995/
    • Welcome back to the scene! Godzilla Motorsports were well regarded back in the day.  My GT-R had work done there prior to my ownership.   SRS (Street Race Solutions) in Toowoomba worth a look.  They've built some pretty wild Skylines. Their YouTube channel is comedic to watch!  I'm sure they're all on the glass BBQ but they get shit done! 🤣
    • Hard to say what the extra connector is, it looks a bit like a coax type connector, so possibly a separate radio/GPS antenna, or even another camera input?  The V37 series (including the Q50), did go through a model refresh in 2020, since Australia didn't get any Q50s newer than 2019, we didn't get any of the refreshed models, so there could also be other unexpected problems to overcome to swap an older Q50 head unit into a new model V37. There probably aren't too many people around that have made these sorts of changes to a Q50/V37, so you might end up being the first if you do decide to go ahead. ACP is Apple Car Play and AA is Android Auto, they are roughly the same thing for the 2 major phone operating systems (Apple's iOS and Android), it allows you to connect your phone and access a number of your phone applications on your car system.  With Nav apps included, so you could use google maps/Waze or whatever your favourite navigation app is, instead of using the built in navi system.  I think this would be a better solution if it is only Navigation that you are looking as swapping the head unit for. GPS signals are the same around the globe as the GPS satellites continuously circle the globe, but it is the head unit that doesn't allow you to load Australian maps, or at least no-one had made an Australian map that will load up on the JDM head unit. Regarding the TV standards, I assume you are referring to the AV inputs?  I haven't ever tried to use them, Japan used a slightly modified version of the US NTSC system, and Australia uses PAL for composite video, that said, I wouldn't be surprised if a video input could work with either system.  That is mostly irrelevant here though, unless you plan to use those inputs for something?
    • If you've got bucket loads of $. Go single. If not, just upgrade the twins, Garrett -9's or whatever the current equivalent is for a healthy 350awkw and leave it at that. Will probably still cost you 10k to do in this day and age.
    • When you looking to buy injectors?? I could possibly sell you my 1d1700s for decent price. Done little work I just need bigger again 😫
    • Is a dirty cheese eating surrender monkey in drag.
