Hey all, had another question which I need help finding the right advise for. I'm needing to replace the clutch in my Series 2 Stagea RS4S shortly and was hoping somebody on here could help me source the right part number for a replacement clutch kit by exedy.
Till this point I was under the impression the Stagea has an R33 GTR gearbox fitted up as factory standard therefor I should be looking at clutch components that suit the 33 but after searching through a few posts already I haven't been able to find a definitive answer or part number.
If anyone has had their clutch replaced using exedy parts I would greatly appreciate knowing what they had fitted and their thoughts on the clutch after having it installed.
Thanks in advanced.
https://www.sau.com.au/forums/topic/300747-s2-stagea-rs4s-manual-clutch-help/
Update
I've got the correct part numbers for the corresponding clutch kits to suite a Series 2 Stagea from 98-on they are as follows for everybody's future reference.
Clutch Size: 250x25.5x24
Pull Type Clutch to suit RB25DET NEO
OEM Replacement: NSK-7333 / $941.20
Heavy Duty Kit: NSK-7333HD / $1,079.95
Heavy Duty Button Kit: NSK-7333HDB / $1,186.95
Heavy Duty Cushion Button Kit: NSK-7333HDCB $1,450.70
i just got the jim berry clutch and im more than happy with it. im fairly sure it was around $900 for him to rebuild the r34gtt clutch thats in the gtr box to a higher clamping pressure and it shits over my mates heavy duty xtreme.
The NSK-7172 series suits all GTR variances from 1993-on, so late model R32 GTR's all the way through to 2002 R34's that feature a pull-type clutch. Coincidentally it also appears to fit Series 2 Stageas as well.
The NSK-7333 suits 98 model-on R34 GT-T's as well as Series 2 Stagea's so it appear that Nissan have made the fitment sizes identical between the GT-T and GTR of the same period probably for convenience.
I would assume the only real difference (if any) is perhaps the torque capacity of the GTR (NSK-7172) clutch may be higher but this I can't confirm.
yer its possible both clutches are the same. kinda weird, as i said that what i have in mine now. exedy has quoted that there nsk7172hd will only hold 363kw at the fly and do not recommend use in stageas. i had a heavy duty put in and i already regret it. its starting to show signs of slipping. (only a few weeks old). my brother inlaw had the same clutch fitted to his r33 rwd and it only lasted a week. but his car has got a few little mods i think its about 300hp atw.
have you bedded the clutch in properly? your supposed to drive really softly for about 1000kms before you go anywhere near WOT otherwise it will slip
will also f**k up if you didn't get the flywheel machined
And cleaned properly!!! machining cast will bring carbon to surface and if not cleaned with solvent will cause slipping & shuddering.
  • 3 years later...
Update
He guys.. a very strong bump here, but I'm wondering if the above information is still valid? Has anyone else gone down a different route and/or have any recommendations in regards to replacing the clutch?
I'm really happy with my Nismo twin-plate Super CopperMix. It cost a fare wedge of cash, but it's light to use, not too bitey, and should easily last quite a while even when (or if) I ever bump up the power levels.
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
