SLY33 Posted December 18, 2003 Share Posted December 18, 2003 Hi all, well its finally done, the turbo was put on last night and morpowa has just finished tuning it. The car made 230rwkw at 17psi (~1.2bar), in a 32 degree dyno cell. They tell me that for the ambient temperature, thats pretty good power. They were also surprised to hear that im running a standard dump pipe! Specs of the car: bosch 044 fuel pump extreme single plate clutch Hybrid FMIC Tomei fuel pressure reg with standard injectors Turbosmart E-boost controller Power FC HKS GT2530 Standard cast dump with 3 inch exhaust I am yet to see the dyno sheets as im still in Sydney, but ill try to post them up this weekend. Im told it drives awesome, spinning easily all the way through 2nd up to 3rd, whereas with the old turbo and 200rwkw it would only just spin in second if you dumped into it hard. So im pretty happy with the result! Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/ Share on other sites More sharing options...
Steve Posted December 18, 2003 Share Posted December 18, 2003 Congrats on a good result, good power for a street car, should come on boost pretty early too. Thats the same power it (a 2530 turbo) made on a mates RB20 at 1.2 bar. I didnt notice a huge amount of top end difference with a front/dump pipe done, but boost came in quicker. Please post up a dyno when you get it. Cheers Steve Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-611826 Share on other sites More sharing options...
Steve Posted December 18, 2003 Share Posted December 18, 2003 Oh, and make sure you wind in a bit more boost and see the difference it make on a HKS turbo:D Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-611828 Share on other sites More sharing options...
VIPERGTSR01 Posted December 18, 2003 Share Posted December 18, 2003 how much is the HKS GT2530 turbo worth? and is that bolt straight on?? because thats the power i would like to have my R33 at soon (happy with 200-250rwkw) Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-611872 Share on other sites More sharing options...
EnricoPalazzo Posted December 18, 2003 Share Posted December 18, 2003 Hey Sly, congrats on the new power. When u get to finally drive it i would love to hear how ur clutch is handling the power cos when i get my new turbo, ill need a clutch and only want a single plater. Cheers. Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-611914 Share on other sites More sharing options...
Sydneykid Posted December 18, 2003 Share Posted December 18, 2003 Hi SLY33, a split dump would add about 10 rwkw. Hi Steve, it good to hear of another with our experience that an RB20 gives the same power as an RB25 when the same stuff is done to it. It happens at higher RPM, but it still happens. Merry Xmas to all. Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-611990 Share on other sites More sharing options...
SLY33 Posted December 18, 2003 Author Share Posted December 18, 2003 the turbo new is around 4 grand?? i got mine for $1800 with less than 2000kms on it which i was skeptical of until i saw/inspected it. it is a straight bolt on if you have the correct T3 flange on it. We had to have some braided lines made up but thats it. you also need a 90degree elbow to point the compressor outlet in the right direction, which came with the turbo. WTF is with the file upload on here? after i click add file, the box goes blank and nothing happens?! Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612019 Share on other sites More sharing options...
SLY33 Posted December 18, 2003 Author Share Posted December 18, 2003 btw the exact power figure is 227.5kw Steve, im sure the 9.0:1 comp ratio would love some more boost! Ill prob keep the boost to 1bar unless i need it, i dont know how long it will like running 1.2bar for before something goes! Am i more likely to do the ring lands in? or does it come down to the tune? Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612024 Share on other sites More sharing options...
Sydneykid Posted December 18, 2003 Share Posted December 18, 2003 Hi Sly33, tuning is very important, you can kill the ring lands at 10 psi with bad tuning or you can safely run 1.5 bar with good tuning. Working on a GTR at the moment that fried the valves, bad tuning = too lean at cruise. It was using 0.5 bar for running in. Get an A/F ratio print out every time you get the car tuned and be suspicious of any A/F ratios over 12.5 to 1 when under boost. Make sure you get a 75%, 50% and 25% throttle opening graph as well. Plus check the closed loop cruise lambda control. Hope that helps Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612034 Share on other sites More sharing options...
Steve Posted December 18, 2003 Share Posted December 18, 2003 Sly, definately give it a go at higher boost. 1.5 bar wont hurt it if, as sydneykid points out, its done with a good tune and a good eye on the AF ratios. Tilbrook now have laptop for GTS power fc, would definately be worth having a look in. And a merry christmas to you too sydneykid, and everyone else:) Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612081 Share on other sites More sharing options...
Guest INASNT Posted December 18, 2003 Share Posted December 18, 2003 nice work! seen a r34 with 2530 pull abit less power than that at around the same boost!! does it run out of puff high up? Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612130 Share on other sites More sharing options...
SLY33 Posted December 18, 2003 Author Share Posted December 18, 2003 im not sure exactly what running out of puff means? do you mean power drop off at the top end? Im yet to drive it, will find out tomorrow. the dyno chart peaks kinda early in my opinion. It looks like it makes the peak power at 149km/hr, then the power line goes flat?! what gear do they do the run in? It must be 4th as the line goes to 170km/hr? my old dyno sheet with the stock turbo done at RPM was done in third gear. Does the gear effect the power reading? I would have thought they would all be done in the same gear. Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612252 Share on other sites More sharing options...
SLY33 Posted December 18, 2003 Author Share Posted December 18, 2003 i have the dyno sheet but i cant attach it to the post! the file attachment box goes blank after i click ADD FILE, then nothing happens... can anyone help? Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612256 Share on other sites More sharing options...
Simonster Posted December 18, 2003 Share Posted December 18, 2003 Hi Sly33, tuning is very important, you can kill the ring lands at 10 psi with bad tuning or you can safely run 1.5 bar with good tuning. Working on a GTR at the moment that fried the valves, bad tuning = too lean at cruise. It was using 0.5 bar for running in.Get an A/F ratio print out every time you get the car tuned and be suspicious of any A/F ratios over 12.5 to 1 when under boost. Make sure you get a 75%, 50% and 25% throttle opening graph as well. Plus check the closed loop cruise lambda control. Hope that helps Hi Sydneykid, I need some educating, what's the purpose of the 75%, 50% and 25% throttle opening graphs? I've just recived a HKS 3037S with a .73ex for my RB25, running an SM2. Any help is appriciated Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612266 Share on other sites More sharing options...
VIPERGTSR01 Posted December 18, 2003 Share Posted December 18, 2003 most dyno runs are usually done in third i think Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612268 Share on other sites More sharing options...
4door_Sleeper Posted December 18, 2003 Share Posted December 18, 2003 VIPERGTSR01, whats with the comment - (happy with 200-250rwkw) I thoght the first rule you need to learn with cars and power is "that you never have enough" :-) SLY - if you want to run in the turbo up the George - give me a yell, it could be fun :-) Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612474 Share on other sites More sharing options...
Steve Posted December 18, 2003 Share Posted December 18, 2003 Simonster, dont want to swap your 0.73 for a 0.87 do you? Sly33, yes running out of puff is when the power drops off at the top. The peak power will be the same no matter what gear its run in. What will be different is the power before peak will be 'fatter' in a lower gear, as power is a function of torque at rpm. Therefore the mechanical advantage of a lower gear will produce more toque (twisting effort) at lower gears, earlier in the rev range. End of the day though, dont look at the dyno too closely, as it is an indication of power and how it is delivered - what is important is firstly that the mods make gains and secondly that the car drives better than before. With that turbo, it should be a really nice street turbo with heaps of mid range for that engine. Should be heaps of fun:) Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612523 Share on other sites More sharing options...
Steve Posted December 18, 2003 Share Posted December 18, 2003 Having said that, I would really like to see the dyno anyhows:) Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612526 Share on other sites More sharing options...
benm Posted December 18, 2003 Share Posted December 18, 2003 most dyno runs are usually done in third i think I'd say its actually 4th gear, of all the dyno days ive been to they have all been in 4th (well over 100 cars) Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612549 Share on other sites More sharing options...
Sydneykid Posted December 18, 2003 Share Posted December 18, 2003 Hi Simonster, you asked "what's the purpose of the 75%, 50% and 25% throttle opening graphs". It is very rare that an engine will have even (linear) flow characteristics at partial throttle openings, less likely they will be the same as at WOT. How often do you drive your car at WOT? Nowhere near as often as you drive it with partial throttle openings. This is particularly important on cars with MAP sensor driven ECU's, not such an issue on cars with AFM driven ECU's. But still well worth checking. It is so much quicker to tune a car only at WOT, after all you would need another 4 power runs to just check the partial throttle A/F ratios. How many more you need to tune it is a factor of how good (experienced) the tuner is. By asking for partial throttle A/F graphs you are telling the tuner that he has to do it all, not take short cuts. The graphs are proof that he has done a complete job. Hope that helps PS; we always tune a car in the 1 to 1 gear, usually 4th. That way we can easily compare the results, if you use different gear ratios you get slight differences which can mask changes after mods are made. If we do something we want to know whether it is better or worse through out the whole RPM range, not just max power at one RPM point. Link to comment https://www.sau.com.au/forums/topic/30077-hksgt2530-results-on-rb25/#findComment-612594 Share on other sites More sharing options...
