Can anyone recommend a Garrett turbo which will bolt on to my standard exhaust manifold. i currently have an xforce 1 piece dump pipe down to cat in 3 inch stainless steel. this will need to match up to back of turbo. Im currently running standard turbo.
Im looking for a garrett which will give me 260 to 280kw at wheels with great response and minimal effort to install.
Does garrett have a bolton replacement which can give me some good power.
i have all the supporting hardware, just need turbo
Thanks guys
unfortunately it won't bolt up to the dump and it will require oil and water lines and intake mods.
then again I am sure a search of the gazillion threads on this will give you are the information you will ever need.
I will have a look for info on GT3071r
thanks guys
Do you think this garrett item is better than the hypergear hiflow turbos?
I have spoken to fred from Turbologic in Wollongong and he recommends buying a new garrett turbo off the shelf rather than spending money to high flow my stock.
After a hiflow, the only true bolt on turbo's are the HKS line, they are more expensive but they are a complete kit. I'd look at the GTRS and the 2853 pro S for that power range. As Wolverine says, the Garrett are not bolt on, they require new dump and oil/water lines.
I believe the hypergears are good functional turbo's. The main diffs are in the country of manufacture and I know the Garrett is ball bearing whereas I think the hypergear are plain bearing, but others can correct me if I'm wrong.
So do A'PEXi (IHI) I had an AX53B70 which I saw was up for sale on these forums again recently... they are also in the same power range
Edited by MintR33
http://www.horsepowerinabox.com/HPIAB2/category12_2.htm
Have a look at the middle of the page, dump pipe is a bolt on but you will need oil and water lines which they also sell which will make it a straight bolt on.
gt3071r kit, comes with everything including dump from GCG, and unlike the other supliers it is clocked ready to bolt on.... which means no custom actuator braket etc...
Anyone reading this topic want to also share their experiences on the "bolt on kits"?
as above, i noted that i purchased a Garret 3071R kit.
got it from a shop in sydney who i think may have ordered it from SA (I could be wrong)
according to my tuner the kit was incorrect with parts missing.
The spacer was not included. cost me an extra $30 organise one locally.
No elbow for the comp housing, not sure if this was to be included though.
studs provided were also imperial, not metric.
also something with either the water or oil line not being the correct size or length.
anyone else know or come across these issues?
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
