Hi Fellas,
Cleaning out my garage and some of the parts that I'd been collecting need to go.
- Stock R33 GTR Turbo's - Turbos have minimal shaft play on them $300
- R33 GTR Pull Type clutch - Clutch is an awesome one have done a couple of hard launches on it and its excellent with a bit of meat left on it, had it in the car but decided to take it out and put a Exedy Cera Kit in the car since i do a lot of city driving. Mechanic has told me that its a Nismo twin plate but i cant seem to find any name of anything on it. - $500
- R33 Gtst Suspension ABS Model - Fronts have Pedders Comfort gas with pedders stiffer springs (Pedders Part Number 2696A)and the rears have standard suspension with pedder stiffer springs(Pedders Part Number 2697). Reason i took them out was because ive put coil overs in the car. No leaks or any noises on the suspension and they have been off the car for about 3 months in the garage - $250
- Random Piping - After the conversion of the car i bought an entire box of r33 standard bov piping from Aaron at import monster and after putting it on looks like there were a couple of double up parts in there - Pm me with what pipe you want and how much your willing to pay
- R33GTSTAuto ECU - $100
- R33GTST Auto Gear surround Black with no ashtray - $50
All parts are located in the Nothern Suburbs of Melbourne, preffered option will be pickup but can courier parts at buyers expense. Parts will be sent the next day after payment is in my bank account.
Take them away guys.......and prices are negotiable as they need to go!!!!
Suspension SOLD!!!
GDZL3R If your talking about the long plastic looking pipe that goes behind the radiator nope dnt have that one....
All the rest is still for sale.....
PRICE DROP!!!!
- Stock R33 GTR Turbo's - Turbos have minimal shaft play on them $250
- R33 GTR Pull Type clutch - Clutch is an awesome one have done a couple of hard launches on it and its excellent with a bit of meat left on it, had it in the car but decided to take it out and put a Exedy Cera Kit in the car since i do a lot of city driving. Mechanic has told me that its a Nismo twin plate but i cant seem to find any name of anything on it. - $450
PARTS NEED TO GO ASAP!!!!!!!!
Sorry Bud, Dont have the stock piping.....got some turbo's or clutch for sale thought ;)
Come on someone buy my turbos and clutch
BUMP
Also have a set of R33 Series 1 Seats for sale. I got given a pair Monza racing seats and Im willing to swap with cash my way if anyone has the correct rails to suit those seats. Let me know please. Seats are in good nik, no rips or tears anywhere.
Fellas got some info on the clutch found some numbers on the front of the clutch and found these numbers 9268200502 and 6e21 which is a nismo gmax spec 1 which has a fair bit of meat on it.
Take it away fellas hurry......
manage13 - will check on that pipe bud and will let you know.
Hope everyone had a good new year
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
