Have you confirmed that the nail has actually penetrated through all the rubber ? I've seen what i thought was a nail in my tyre before - turned out to just be the head mashed into the rubber with no puncture.
I have had a semi slick repaired after a puncture before, and done 3 track days on it after the repair with no dramas. The repair needs to be done properly, but i dont see how it would change the performance of the tyre all that much ? Then again, both of the above posters have been into motorsport a lot longer than I have, so they probably know what they are talking about :)
hahah well in this case you've actually tried it and lived so you are one up on me! I'm not giving it a go, tyres just take too much punishment, I've seen (and had) too many let go for no reason to trust that that does have something wrong
I have had an RE55 repaired then tested at over 200kmh at PI. In my case the tyre was almost new and I couldn't bear to throw it away....had it been older I probably would've thrown it due to the reasons Dunc mentions above.
I don't have an issue with it but be aware that there is a possibility (however slight) that the tyre will let go.
yer it has def punctured it. pumped it up and splashed water over it = bubbles.
there is about 70% tread left on them so would love to repair it if i know its safe and tried by a number of guys on here.
i had a front left let go on me not that long ago on Lakeside braking from 200km/h so i know that "oh f**k me" feeling and really wanna make sure its safe.
other problem is that i cant just replace one tire with full tread on a gtr can i ??? in regards to slight difference in rolling diameter or am i worrying to much..
cheers guys
cheers guys
you're worrying too much. If they are at 70% tread, your talking a few mm difference in rolling diameter. ATTESSA is picky.. but not that picky :blink:
i priced one of my re55s once, got it fix, my next trake day i did my fastest time, not saying the tires was better then b4 but it was fine at the track, just tell bob jane of whoever that u race on these tires so they do a great job!
best of luck
how many laps in total have you done on it after the repair. was it only sprints or 6+ lap sessions on them
cheers
it really depends on where it's punctured and how badly. anywhere near or on the sidewall = throwaway. if it's on the tread face and is not too large consider repairing it. take it somewhere and explain that you will be doing over 200kph and will be doing heavy braking etc. get an internal vulcanised repair done and then put that tyre on the least "used" spot (most likely left or right rear depending on the track).
it certainly is a risk. have you ever watched the tyre cam in v8 supercars etc and seen the kind of loads that tyres are under on a track? then imagine that tyre with a hole and a repair on it. but I'e done it once before and I know many other tight arses who have without issue but just be aware of what you're in for...
    • Alright guys, I've got good odds the motor survives due to a majority of spare parts. Who's taking bets on clutch, who's on transmission, and who's go diff? Happy to also take bets on if it still overheats in traffic or not 😛     Car looks amazing by the way. I've never been a fan of R34 rears, so really, I don't think any body kit etc solves that for myself, but the front end looks amazing!
    • As an ex-skyline owner Going off how these things are now "modern classics", I would keep the twins and just "refresh" bits that are required for reliable power and have a car you can take out for a cruise whenever you get the itch As a idiot who cannot leave things alone Going deep into the "rabbit hole" is a easy thing to do, as previously mentioned, once you start it becomes a slippery slope, wirh lots of supporting mods, and possibly rebuilds, and unless you have a bottomless pit of funds, the car can spend most of its life sitting in the garage,  broken, waiting for parts, or building more funds For a classic like a R32 GTR Basically, a reliable OEM+ refresh, that isn't a broken garage queen, is alot better than a car that you build, then break, then fix, then break again And it isn't just the engine you need to worry about, these beasties are getting on in age, and all parts are getting, and have got, expensive, the days of picking up cheap replacement engines and other driveline parts are well and truly over The funds not spent on going a single with quality parts, and with all the other other bits required to make it happen, could be spent on refreshing alot of other parts A wise man once said "If you cannot afford 2 GTR's, you cannot afford 1", I also believe he said this about 20 years ago when you could pick up a clean R32 GTR up for around $20k My advice for a R32 GTR (the one and only true Godzilla in my mind) is to think holistically about the whole car, the body, the power train, the suspension, the brakes, and the driveline SAU is a wealth of knowledge with decades of Skyline experience,  from stock, to OEM+, to modified to varying degrees, to full on or weekend or dedicated racecars, as well as full on money pits that rarely leave their garage Treat the old girl nice and give her what she deserves, you are a lucky man to own such a classic car
    • For that price you could buy the hypergear turbo (big fan as I run one) and the Haltech ECU..
    • +1 for the Elite 2500. Get some new knock sensors while you are at it (pretty cheap), look up the TAARKS Nissan knock sensor kit. You may also want to get new coils (R35gtr) while your at it (assuming your on stock ones), as they are a liability. Mine started right up and idled fine on the base map. Also go MAP over MAF, as said above, Haltech make this super simple right out the box. Another fanboy of DBW here, Outsider Garage from your neck of the woods make some nice conversion gear for the R33 (that’s where I got some of my gear from).
    • Nvm ignore this I read it wrong
