Hi Folks,
I've got a modified RB30 head to go on my patrol which I am currently re-conditioning. It was removed from an R31 skyline some time ago. It is fitted with a different camshaft, vlave springs and cam gear when compared to an un-modified head. Both the inlet and exhaust ports have been enlarged. I hoping someone might recognise the markings I found on various parts in order to help me identify the thing and it's potential.
The head itself has the name John Chard 1999 or John Charo 1999 engraved by hand along the back rocker cover sealing surface.
The outer valve springs have been 'upgraded'. I note that the 1, 2 and 3 exhaust valves do not have the reverse wound springs fitted as indicated in the patrol handbook. I am unsure why nissan would have specified reverse wound springs for the 1, 2 and 3 exhaust valves only, and I wonder what effect - if any - is likely to occur by not having them.
The camshaft is stamped with 2 codes at the front (under the cam gear) KLJ and H14. It measures different to the stnadard patrol (RB30S) cam in overall lobe height. It would be nice to know what brand/grind it is to make sure I have it dialled in correctly when re-assembling the motor. I have searched around the 'net for a few days now with no real success.
The cam gear appears to be a custom modified unit to allow vernier style adjustment of the cam timing.
For what it's worth, the patrol runs Motec EFI - so being able to tune it effectively poses no real problem once installed. Any help in identifying the origin of the mods and parts would be greatly appreciated.
PS any enlightenment on the valve spring specs for 1, 2 and 3 exhaust also appreciated.
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 馃槂
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
