Thanks Santa (the neverending trials of the 400,000klm, 400kw, RB30, manual swapped Stagea)
Well it has been a while, but I picked up the car from Hills Motorsport yesterday.
It got dropped off as a standard engine bay with a pretty sick (not sik) motor. It came back like this:
Basically it has an rb30 bottom end, skyline rb25 head, forged rods and pistons, new bearings, seals etc etc.
High mount ebay nugget t3/t4 turbo (go china!)
Front facing plenum
Pretty much everything else as before (powerfc, manual, sydneykid shocks and springs, d2 8spot front brakes).
So far its only being run in so it hasn't been pushed or tuned - but the torque down low is amazing and a real turn around from the normal (slightly disappointing) standard stagea feeling.
Turbo is making 7psi at 2,000 so I'm sure it will come on nice and early as I hoped, the run we did at 10psi had 160awkw which is a little more than the old setup made on 14psi - but the response even off boost is the real difference.
Very happy A+++ would buy again!
Congratulations! Good to hear. I got an RB30 bottom end (not installed as yet) because unforged it will stand more kw than the RB25 unforged and also have more torque all round . I would guess your engine will make around 280 - 300awkw now and have the potential for much more if you choose! [would you mind PM the drive in drive out price to me? I expect mine will be a little less because I am not getting forged rods and pistons and the front facing plenum will have to wait].
I bet you are a happy camper.
I drove around the yellow thing around today and all I think about is how another 500cc or so would make the car a whole lot nicer to drive in traffic.
How much did you spend on the new motor?
yeah it is beautiful to drive, especially pulling away from idle. no idea what it will actually end up doing, I was aiming for about 250kw but a focus on torque.
If I ever decide to get silly it has all of the required supporting stuff except injectors and an expensive turbo to go 300+.
Cost was about $10k but that did include some other stuff like a new alarm, clutch, intercooler etc etc.
I was going to keep the standard manifold but there may have been clearance issues to the bonnet, and the china front facing manifolds are dirt cheap these days.
$10k . . . i dont think i could ever part with that cash with out getting reamed by the miss's haha.
in one go though. here and there easy, but in one hit.
would have to spoil her for a month before to soften her up
I'd be pretty happy with that for $10k mate. you've got the goods plus a very clean, professional looking job.
if i may have a small nitpick though ( ;) ), it looks like your heatshield/airbox is covering/including your charged air intercooler pipe. it's something small, but i'd be keeping that on the outside of the airbox :P
edit:
tj, you've picked the wrong one! i've already pre-approved a $30k supra with mine ;) i'm still working on the 30k engine package though :):(
Edited by pyro-ns
Pretty good drive in drive out price
Other expense that you have not listed is the sump adaptor to suit the awd sump and rb30 block. These are not cheap
Could you find which one they used and the cost of it?
if i may have a small nitpick though ( :blink: ), it looks like your heatshield/airbox is covering/including your charged air intercooler pipe. it's something small, but i'd be keeping that on the outside of the airbox ;)
yeah I am very happy with the price. $10k is a lot of money, but you have to look at how much time and parts there are in this build. I beleive it was very cheap for the work that was done. Good call on the cooler pipe, might see what I can do.
Nice, were there any issues getting it in and running, or was it all fairly straightforward?
nothing but trouble getting it running, but nothing to do with the job the shop did. For instance, once the whole thing had been assembled and put on the dyno the first time they discovered a crack in the block at a welsh plug at the rear of the head. I hadn't asked for it to be xrayed, they took a chance and lost. And then the second time it was put together the f**king alarm control module failed - but of course that is the last thing you think to check.
and of course the R34 GTT PFC is not a direct fit in my car which needed some stuffing around too.
once it was all together it has been fine though, and the run-in tune was quick and easy. Idle control has been a bit of a pain with the new plenum/throttle/cruise control/aac mvoed etc etc but its all good now.
Looks good!
what throttle body did you use on the plenum?
pretty sure it is the standard tb - I am not looking for more than 300kw from this setup and I'm sure the standard one will be enough for that.
yeah they used the pro-engines sump adaptor, about $800 including all fasteners from memory, fit first time without any mods required. also another complexity in a 4wd/rb30 is the oil pick up because the rb30 point is right where the driveshaft goes through the diff. the guys at hills modified it to plug the normal hole and drill into the block at the right place same as a 26 block - very precise work required to get that right. often people just run external oil feeds to the pump, that is probably both cheaper and easier.
once we have a house, the women don't care where my spare cash goes josh :blink: but for now it would be hell haha
lol don't you beleive it! once you have a house you have kids, then it's ALL over.
lucky you have the best wife ever eh Duncan?
:blink:
(and yes, I have a built in radar which automatically detects any thread you post comments about spending money on cars in)
Nice mate!
If you're going Chinese for the intake plenum (the greddy knockoffs) make sure you check for leaks before you drive it away. Look especially hard at the.. stalks? where it comes out of the engine, mine had a pinprick - 1 drop and thanks to the tuners these guys found and fixed it!
Leaks are easy to fix if spotted right away - a cooked engine is not what you want!
But that is bloody tidy, I've just had some work done myself, so I'll put up my build thread when I get a proper camera
Its not over. You wait till your 66. :cheers:
Child slavery was invented by parents who wanted to still be able to afford such luxurys as motoracing.
nice work Duncan, the 30s do drive alot nicer than 25/26 capacity motors, especially in stop start traffic they just pull away from idle with ease.
You can buy the internal oil pickup with the pro engines sump adaptor kit and it bolts straight on without any hassle.
One thing to mention is when choosing this combo i feel a small turbo is not such a good idea (not aimed at you duncan). I run a 3076r on mine and it suffers from incrediblely shocking fuel economy, due to the car sitting on 0 on the vac/boost gauge at 100kmh on the freeway. Mines making over 20psi at 2900rpm which when on 100kmh on freeway its sitting on 2700rpm or so doesnt leave much until its wanting to get onto boost.
Im going to bolt my t04z on mine and see how it is, then probably get some 2860-5 lowmounts for longterm to keep it looking stock (i run 26 head)
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
