Hey guys,
Im having this problem with my 32 no matter when my car is on the heater pumps out hot air(even if the Climate control is off). Also when i change the temp on the CC it doesnt change the temp that is pumped out.
Do you guys think its just the Climate control or is it more to it.
Cheers,
Dave
https://www.sau.com.au/forums/topic/300864-heater-always-on/
Yep, it sounds like a problem similar to mine. I think it's the "mixer door" which controls how much hot air gets pumped into the car. I haven't actually fixed my problem yet, but there are some threads on this forum about it.
Have a listen down underneath the steering wheel (may be different in a 32 though) and you may hear a kind of motor going back and forth quickly. If you get down into the footwell and look upwards you can actually see it moving back and forth.
You should be able to go onto complete cold by selecting the coldest temp, or complete hot by selecting the hottest temp. You should hear the mixer door stop moving at this point.
One thing to check is the temp sensor located just to the left of the steering wheel. Pull off the dash and make sure it's connected properly.
My sensor was fine and I even had a guy look at the mixer door but even though he got it to work at some stage, it's gone back to its old tricks. A real pain in winter time when it tries to mix a bit of heat in, but in summer it's on full cold anyway so it doesn't make a difference :(
  • 4 weeks later...
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
    • To install new hicas ball joints do i really need to pay for the Frenchys hicas install tool? Or can i use something like this? https://www.ebay.co.uk/itm/395524214497?_trkparms=amclksrc%3DITM%26aid%3D1110018%26algo%3DHOMESPLICE.COMPLISTINGS%26ao%3D1%26asc%3D281023%2C280568%2C280618%26meid%3D4018390c9ba246f794ed58b8b19ec80a%26pid%3D101430%26rk%3D4%26rkt%3D12%26sd%3D205160403603%26itm%3D395524214497%26pmt%3D1%26noa%3D0%26pg%3D2332490%26algv%3DCompVIDesktopATF2V2AndXaiHotClickWithCompV6WithEbertNRTRecall%26brand%3DUnbranded&_trksid=p2332490.c101430.m2460&itmprp=cksum%3A3955242144974018390c9ba246f794ed58b8b19ec80a|enc%3AAQAKAAABMDJfxvEKz%2FWsdyy97PIVwAhtkTIJPGKp%2Bu7TYjjsvNO4eN9duTRR%2FSVFYts6UXmN8tSK75ee0LypjLaKkPNQ2gkat4DyNLnViXKBVpI1%2B5fAYfWiGJa5QlqEPseqbSJUD9gVo2KSXbnmQjuPDJH4flTH2bOLSO%2FvMrLjgPDIc7vGrlKtoSauZb0q%2Fu43zLR0J8tg1z5dPMV%2FcHtnqRYXb7R7V8G%2FrQGhpY1sWtGJXc4TWc78ccs69UXnMiCqqd05ITd%2BY7Vwbq5Uzd%2FWhmiZCytO66vqDnbJn03qN%2Bin0ImF5sgbgu9uD45tXNN8cr4IWfqzIEEpaKcgqilwbTDxMkIQ4sGcgz7IhYONV017vE6P9ksZ7n%2FFVwgs3kAfMb0%2FLGjwaqhwo0yilTIjGHg9mwU%3D|ampid%3APL_CLK|clp%3A2332490&itmmeta=01JMR0X9WMB8DPEX82P2P3CRXN
    • I would be lying if I said I wasn't interested in what MCM were going to do with the NC I really enjoy their banter and occasional collaborations (like Alan from TSF, Ben from BCW, or any of the Haltech guys throwing around their experience), and I have probably watched everything they have put out
    • Not yet, we basically drove it to a private road, got the logs and drove it straight back. I think I need a new passenger seat belt after the mrs squeezed the life out of it.
