Hi Stuart,
I'm using the Nulon 10W/40 for the motor and Nulon for the gearbox. The gearbox one is for Matic J(As well as others). Diff oil should be the same as an R34 GTR me thinks.
You need about 5lt's for the motor and about 8lt's for a fully drained gearbox.
cheers
so Matic J Synthetic for the Auto and transfer, 75w90 GL4 front diff and 80w90 LSD GL5 for th rear diff.....
This sound OK?
Transfer case is same atf as gearbox and steering. Get a 20L drum as gearbox will take about 14L - you need to pump it out via the cooler pipes to get it all.
  • 4 months later...
Any updates on how this went?
Looking to do the same. Thinking of http://www.nulon.com.au/products/Full_Synt...smission_Fluid/ in the auto and Red Line 'Lightweight Shockproof' for the diffs.
Comments?
Comments?
Exactly what I have in my car.
No complaints whatsoever :happy:
Good to hear.
So how much do I need? Is the 20l comment above accurate?
How much of the Red Line?
Thanks
3 bottles of Redline Lightweight Shockproof will leave you with some left over. Get them from for damn good pricing :)
You will need around 8.3L of trans oil if filling from empty.... if flushing, Nissan use 10.5 on their machine.
As an aside, you can also use the Nulon trans fluid for the ATTESSA and power steering (Nissan use Matic D for these)
Edited by iamhe77
Good to hear.
Thanks
On the gearbox without flushing it completely you will be hard pressed getting 5lt's of the old oil out even with twin after market transcoolers( :))....so 5lt's if your just want to change what's in there without flushing. If not I think it's about 7lt's or 8lt's plus a flush....IMO unless your oil is cooked I would not bother with a complete flush.
As for the diff's.....haven't done em yet so.....I guess someone else can answer that.
I had a 60% blocked radiator for a while, so I wouldn't rule out cooked.
Got details on the after market oil cooler? I'm noticing the gearbox seems to start hunting a little bit after getting heated up on a long highway climb. Wouldn't mind getting a bigger cooler in there if it isn't a huge expensive job.
Any trans cooler will be of benefit.
Personally I am running a PWR "6-cylinder" unit and have mounted it on a bracket behind the grill as you can see below (obv without the grill).
There are plenty of cheap trans coolers. Just note that if you are using a 3/8" transmission hose, you will need to make sure of the connection to the radiator cooler as I believe they are slightly smaller than 3/8".
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
