EDIT: oops, fixed title...
hey guys,
Some of this has come up before a few times already but I just thought I'd give my thoughts on it.
I decided to remove the panel off the front of the M35 airbox to see what the difference would be. I'm too stingy to buy a powerduct (like on the V35 and PM35 stagea) so I just left it as is, my rationale being that the airbox is right up against the front anyway, and when you're in motion it'll be getting nice fresh air.
Anyway, so obviously the first thing I noticed was the sound. It is awesome. I just didn't expect it to be anything like what it is. Makes the car sound soooooo much better under boost/heavy throttle. My fuel usage did suffer over the following 300km though because I just had to hear it over and over again...which meant a heavier-than-normal right foot...but this should sort itself out as I get more used to it. :down:
The other thing I did last week was grab a bottle of Caltex Techron 5000 and pour it in the fuel tank. Its available from most caltex servo's for about $13.
With both of these things its hard to say conclusively whether there is a benefit or whether I've just had a good run, but the car seems to breathe better (ie. less restriction when you press the accelerator) and overall has better performance all-round. In any case the engine sound is definitely conclusive - and its worth doing just for that!
I highly recommend the techron, but obviously do your own research if you're not sure about it...
Thing is, I always use bp ultimate but still, I know my intake is covered in black soot so I figured the engine internals could be as well...
The cleaning agent in any 98RON fuel is probably pretty good but none of them are anywhere near as concentrated as a bottle of techron 5000. I've read many good reviews about it online which is why I thought of giving it a go. it gets 2 thumbs up from me :)
Edited by pixel8r
https://www.sau.com.au/forums/topic/300887-airbox-panel-on-m35/
I just fitted an intake on an M35 yesterday, I used some 1 inch square foam to seal around the front of the airbox and trimmed 4 inches off the bonnet rubber, worked great. No need for a powa duct.
got a pic?
Nub question, but how do you remove the front section of the air box to replace the filter?
I've taken off the front 'lip' duct, unbolted the airbox itself (10mm bolt on the right), detached what I presume is the airflow meter and unclamped the rubber hose from the back of the box.
But the air box is still attached to something underneath it and there isn't enough room to get front of the air box off enough to swap the filters.
Suggestions?
Lovely job thanks Scotty.... :cheers:
post-20696-1261441284_thumb.jpg He even trimmed the rubber edge on the bonnet... post-20696-1261441298_thumb.jpg
Nicely showing off the new intake piping there too :santa:
Sound = 10/10
Performance = a bit subjective. Definitely dont think I've lost any performance. It does certainly feel like there is less restriction - particularly at low revs. More kw? I dont know. Even if there was, it would be very slight. I just love the sound :)
Yes the pick up is much better than previously, so fuel consumption not an issue, just enjoying it...
But going down to the Valley at the weekend so will see how it does then..
So have you noticed a difference Nick?
Or are you still learning how to drive it economically?
    • I agree on doing some better than factory pistons, rods, and oil pump. For anyone using the vehicle on the road, I don't get why everyone wants big cams. The stock cam profile, with some more lift would be mint for road usage. Everyone going big cams and then wondering why it isn't as responsive in traffic, when they've shifted the torque curve upwards an additional 1000RPM. Make torque, at lower RPM. Sure it's not as cool as claiming "500KW" and revving it to 8,0000RPM, but that same torque 2,000RPM earlier... Then you don't need the extremely high end pistons and rods, and blah blah blah.
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
