Short quickie question.....
Are half roll cages legal for a street car in SA??
I asked a cop and he said they wouldnt defect them unless your head could come into contact with them....
But doesnt mean its legal or not...
anyone had any experiance with them
https://www.sau.com.au/forums/topic/300888-half-roll-cages/
Speak to a roll cage place as they should know. Rear seat belt holes need to be welded up and the cage designed properly. Will also need to be rego'd as a 2 seater.
I have seen walker chasis work and it's bloody awesome. It's where I'll be going to later on.
https://www.sau.com.au/forums/topic/300888-half-roll-cages/#findComment-4996793
afaik they are street legal providing the stuff Luke mentioned above is done. a good example is the Clubsport pack for 911 GT2/GT3 with the street legal half cage.
car should be registered as a two seater with no rear belts or points. i am going through the process so can let you know the outcome next month.
https://www.sau.com.au/forums/topic/300888-half-roll-cages/#findComment-4996822
It's legal, yes, but must be registered as a 2 seater.
And all the shit in the back has to be welded up. And cover the rest of the shit in padding. And make sure the shit is all good.
Shit yeah.
Just expect to be pulled over every 10 minutes and questioned.
https://www.sau.com.au/forums/topic/300888-half-roll-cages/#findComment-4997078
Also you will find that only a coupe can be registered as a 2 seater, if you have a 4 door you will have to make the fix the rear doors. Every thing else is correct except they can be weld in, and you have to have 150mm head clearance to the roll cage with the seat in it's rear most position.
and this is the most correct thing said in here;
Shit yeah.
https://www.sau.com.au/forums/topic/300888-half-roll-cages/#findComment-4997302
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
