Hey Everyone
I been thinking for while of getting a FMIC, but now that ive starting looking into it theres alot of different sizes and core dimensions etc...
I have a series 1 GTS-T M-SPEC will the FMIC fit without much mods to the front bar?
Just wanted to know what other people have put on and dimensions please.. my Budget is about $2000 installed i dont want to blow my budget.
Im also getting the exhaust done dump pipe and high flow cat any recomendations on that would be great also!
Thanks!
https://www.sau.com.au/forums/topic/30089-fmic/
You have to cut the bar for any decent sized fmic. I haven't done it myself but the workshop that installed the fmic did so without too many dramas. I don't think it's that hard.
Dump pipe and cat - get one of each from BATMBL! See the car parts trading forum.
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-611765
I'm thinking of putting a GTR cooler on mine... I figure i only wanna run around 12-14PSI (GTR runs that) and it should virtually bolt straight on no worries...
Plus I only wanna take the car to a max of around 200RWKW (for the time being) so the GTR cooler should do the trick...
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-612668
Dimensions i think are around 600x300x70 (but don't quote me on that. Piping work is easy, just take it an exhaust place and they'll get it done for you for around $300-$400.
Sounds like a GTR intercooler will do the trick!!! Thanks alot Guys now have to start find one for a good price.
What u reckon is a reasonable price? $500-700??????
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-613350
If you don't want to cut the front bar yet still get good performance out of the IC use a Bar and plate.
Mine fits perfectly behind the front bar.
Its rated at its optimum of 580hp with a 1.5psi pressure drop.
From memory its got 60-63mm inlet/outlet 2.5", 600 x 300 x 90. I think.. :D
https://www.sau.com.au/forums/topic/30089-fmic/#findComment-613384
    • See my post here If you put the Haltech in, you won't have to worry about any of that. And, in case you're worrying about my lack of credentials in doing your exact swap, I put a Neo in an R32. There has never been a stock boost solenoid near my car and the Neo's ECU has never cared. Nor should it, because it is electronically impossible for it to care.
    • That's 100% wrong. Did you wire in the boost sensor? If you did not, then that is 101% your answer. Neo ECUs do suck a bit.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
