1991 kps13 Silvia
Sr20de
5 Speed manual
viscos lsd
Mods
Exhaust/Engine/Driveline
4 into 1 Jasma extractors
2.5" De-cat pipe
2.5" D&T cat back exhaust system
Drift pod filter
New genuine Nissan water pump- fitted March this year
Serviced every 5000kms
KTS poly gearbox mount
Xtreem heavy duty clutch
Suspension/Steering/Brakes
ISC coilovers
F+R Whiteline heavy duty adjustable swaybars
F+R Cusco strut braces
New tie rod ends- Fitted March this year
New steering rack boots- Fitted March this year
Super Pro lower controll arm bushes
Slotted front discs
New front brake pads
New rear disks- Under 1000kms 0ld
Qfm rear brake pads- Under 1000kms old
Non Hicas rear end
Interior
Spotless and in excellant condition
Dash mat
s14 seats
Drift steering wheel
Nismo look-alike gear knob
White face dials- Light up blue
JVC cd player
JVC rear speakers
Sony front speakers
Exterior
Spotless paintwork with NO dents or scratches
Rare factory Midnight green
Vertex bodykit
18' Lenso Passion wheels with 235/40 Bridgestone Potenza's
Clear front corner lights
Slotted grill
Spare Parts
Standard exhaust manifold
Standard exhaust
Standard Cat
Standard swaybars
Standard front springs
Standard wheels
Price- A steal at $8000
Or swap for v8 commodore or falcon of similar value. Sedan or ute.
Ph: 0432552045
https://www.sau.com.au/forums/topic/300896-s13-silvia-sr20de-sa/
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
