ill make it easy, can someone please explain to me how to set up the whole coolant feed & return then i can cover all bases, the coolant feed has an 18mm thread that bolts into the turbo & a 14mm thread that bolts into the rear end of the block, the only confusing thing is the 14mm connection into the rear end of the block is already holding a copper circle with a rubber hose running off of it up the back of my block, im just unsure what im meant to do here, should i put both copper circles (one from the coolant feed & the one thats already there) on the same 14mm bolt meaning there would be 2 copper circles on the same bolt, or do i bolt one of them elsewhere? is it possible that the existing one is just temporary because i didnt have a turbo?.. the coolant return pipe has an 18mm thread into the turbo as well but doesnt have a screw on the other end of it just a rubber hose thats meant to go somewhere i am unsure where its meant to go, any help would be much appreciated.
Edited by azzafreddy
  • Replies 118
the pipe with the copper circle thingy your talking about are banjo bolts
the water feed comes from that 14mm thread on the block and goes to the turbo, than the other line goes from the turbo with that copper circle thing your talking about to that rubber hose your talking about... the rubber hose part travels behind the engine and over to the inlet side of the block, there will either be a fitting off the plenum that the hose is suppose to go to or it'll be a t piece off one of your heater lines...
okay im going to explain this using pictures that i found on another forum..
these photos are of an rb25det rebuild, with the same braided turbo coolant/oil lines that i have on order.
im not sure which line is the coolant feed and which is the return, but at this stage its not what im trying to find out, im pretty sure this is the feed..
im pretty sure this is the return going to the back of the block..
ok what i've been trying to explain, theres 2 yellow circles on the 2nd picture, at the moment there is a rubber hose going between them 2 coolant connections, is it just temporary because my turbo has been removed? i am in the process of setting my turbo up again, ive done all the work apart from the coolant lines, should i set them up exactly like the pictures show?
p.s i do have the same metal braided lines on order hopefully they are here tomorrow..
please dont hesitate to tell me if this doesnt make sense i've been trying my hardest to explain it, next step ill take some pictures of my engine.
the car did run quite well after a while, but never the less the engine was setup to run with a turbo, taking the turbo out isn't the greatest of ideas.. i'm glad with what i have learned from this forum & appreciate all the people that are willing to help out, ill post up some pics when i'm finished & the cars going well.. cheers.
well, if anything else this has been a very enjoyable read.
hah ha you've gotten a good flaming hey
and you owe SECURITY a good long b/j, gold bullion or your firstborn hah ha.
good luck with it all
alright everything is done, no leaks, everythings been double checked & tightened well. car seems to run great, however there is 1 thing that i am slightly concerned about, after about a min of running a light smoke comes from around the turbo area, i had it running for 10 mins like that & the temperature guage did not move past half way. i was thinking about something 'mad082' said a while ago about disconnecting something & turning the engine over to get the oil into the turbo lines before actually starting the car, how do i do this? i cant find the post for the life of me.. cheers.
cars still running alright, smokes dissapeared completely, it gets hot allot quicker but never goes over half way, there is one thing thats annoying me when i slow down for an intersection go to third then second then turn, sometimes it stalls like i can have my clutch all the way in and the car shuts off & i turn the key to restart whilst still rolling and continue on in 2nd gear, also the other day when i first drove it after i put the turbo in it was possible to change gears without the blow off valve sounding (slight touch of boost), now i have to rev it right out because it runs really low revs for what speed im doing, for instance i sit on 2000 rpm or a tad under when im going 60 thats a really strange feeling to me.. possibly a tune?
i think he means full boost.
check for a vacuum leak somewhere in the cooler/inlet piping. also check the AAC valve guide in the DIY for the stalling issue, also clean your AFM.
the tune should be running back to normal now but try 'refreshing' the ECU;
disconnect the -ve terminal of the battery and pump your brakes for a good min or 2 till you're sure the car is completely drained of power. reconnect the terminal then take the car for a 'spirited' drive.
if that doesnt fix it then post up some more details of what its doing.
    • Not stock. All remade. Mostly looks stock because the pipes run to and from the standard holes in the inner guard to get to the return flow FMIC. I'm not sure which question you're trying to ask, because it seems like "stock position" vs "stock position".
    • Hey, it's a GT-R, it's just as significant a moment as mine😁 It's not ideal when things are uncertain; I'm the type of person that always has a set plan for things in life so being unsure of this plan puts me in a weird place mentally.
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card style AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had no flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
