hey everyone
the left HID on my s2 rs4 has stopped working.
the globe used to light up but only about half bright..
thel a few flickers..
then it turns off
now wont turn on at all.
i had a spare D2R globe.. plugged in , still no workie
where is the balast on a stagea?
and is there any way to test it ?
cheers :P
https://www.sau.com.au/forums/topic/300907-headlight-problems/
Hi there, you could try bulb(s) from LH offending cct in RH working cct to confirm your bulb(s) are good. Dunno where ballasts are, I have S1, maybe trace wiring back? I should imagine the ballasts would be close to headlamp location but. Also check out diy Stagea section for suggestions if you haven't already.
Cheers GW
Edit: http://www.skylinesaustralia.com/forums/Xe...l&hl=hid%2A
Maybe helpful?
Edited by 260tech
they aren't actually on the backside of the headlight if you want to get technical, cam
if you take the headlight out it is bolted to the inner side of the housing, pretty much between the main headlight unit and the highbeams
and i have a pair of balasts here too from when mine got complied - chuck me an offer
Ballast on S2 stagea, between headlight and hi beam - bolted to side of headlight.
Will have to remove headlight to access - remove grill, then hi beam - front bar stays in place
###dont forget bolts from rear of rad support panel###
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
