Doing a bit of research I discovered that the A32/A33 Maxima has a 72mm TB, which is the size I want to use on a forward facing plenum when I get one.
Would anybody with a suitable plenum (Greddy, Plazmaman, etc) on their RB25 be willing to lend a hand to see if this TB will fit? If my idea works it could save a few people hundreds of dollars as you wouldn't have to buy a billet CNC item for silly amounts of cash.
This won't be until after Xmas but let me know if you're happy to help out - i'll bring beers.
https://www.sau.com.au/forums/topic/300954-rb25-plenum-tb-experiment/
you can get an adapter to fit the stock throttle body to the Greddy plenum or just fit a Q45 throttle body. why go to the effort of reinventing the wheel?
Having spoken to Plazmaman they recommended the 72mm TB over an 80mm or 90mm item for better response, so that's what i'm planning on using. Given that a lot of Nissan parts are interchangable I'd thought I'd see if this would work on one of their plenums. If the bolt hole locations are different I'll see how much TRD will charge to machine an adapter plate. The last thing I had them machine for me was insanely cheap, so I doubt this will cost much. All up I reckon it would be cheaper than a Plazmaman TB ($500) to buy the part I want & have an adapter machined.
Why spend $500 when i don't have to?
why not just buy the plenum from plazmaman that fits the std TB?
and of course he will tell you that "his" 72mm squillion dollar TB is better than an ebay 80mm one or the standard one.
In my experience changing throttle bodies on car that doesnt have ITBs does sweet FA especially boosted ones....there are plently of 350rwkw+ rb25s running around with the standard intake/TB combo
Standard TB is 60mm, 72mm should give better response - that's the aim for the car as I'm not into dyno figures & dick measuring kw contests, I just want the car to be very responsive for drifting.
Naturally Plazmaman have given me a sales pitch to sell their own TB at 3billion % mark up, so I'm trying to find an alternative. If my plan doesn't work i've lost all of $60 getting the part from Japan (Aussie wreckers wanted $110 or more incl delivery) and can still put the standard TB on.
I've never heard of anybody trying to do this before so I thought I'd give it a shot. Somebody has to think outside the box, otherwise we'd all get ripped off more often.
Im all for giving it a go mate :D
just saying that dont expect a massive difference, do you have a pic of how the cable mount etc are.
the maxima is FWD so the donk is mounted East-West so while the bolt holes might line up, but there may be a lot of stuffing around getting the cable to line up properly
R33
A32
The plug location is different as are some of the lines, but we'll see what happens once I get the plenum. The TB should arrive from Japan in a couple of weeks - i'm buying a few parts at once but most of the shops shut down over the end of year break and don't open until next week at the earliest.
Edited by a31rb25
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
    • from an old insurance company i was with (Budget Direct) I had someone roll back into me at the lights got them to pull over. Got a picture of thier licence with address, had a dash cam video and, thier phone number. But only had 3rd party on the shitbox i was driving. insurance did nothing, cops wouldn't do anything due to the value of the damage (under $3000) so i just had to suck it up and go to U Pull It.
    • Small Update on the Exhaust Situation A 200-cell cat was a bit too expensive for now, so I had the exhaust shop fabricate a new exhaust from the cat to the rear and an exhaust tip. I went this route to avoid cutting into the original exhaust and keep it intact. It’s essentially straight-piped, and the sound is noticeably different. The exhaust tip came with a silencer, so if it gets too loud, I can easily install it to tone things down slightly. Right now, the car bangs and pops like crazy -- which I personally love. In the future, I might add a resonator or a 200-cell cat, as niZmO_Man suggested, but for now, I’m really happy with how it turned out.
    • And that's a massive problem, because deadshits will deadshit and give you false details. At least in these days of mobile cameraphones, it is trivial to take photos of any ID they are carrying at the same time as the 300 photo extensive documentation of the state of the vehicles that I recommend even for minor incidents. And you get photos of the person's face, any visible tatoos, etc etc, while you're at it. Then you try to avoid mentioning that you're fully capable of making explosives of various power levels and will wreck their shit if you are forced to hunt them down.
