I would love to get my setup a bit more responsive than it is now, I have a hypergear atr28/g3 highflow on an auto rb25neo. Have nistune, exhaust, t-bar boost control stock injectors etc.
Getting 230rwkw at 15psi which is great but boost doesn't reach peak till almost 4000rpm.
Would changing the boost control to ebc or changing the stock actuator help it boost quicker or is it just the size of the turbo? Anything else i can add on other than a high stall on the auto?
Cheers...
shorter cooler pipen wil help a lil bit, dont go ebc,...... that equals more lag and spikes then tpeice, (been down the road myself $400 ebc = shit compare to $20 mech T-peice) maybe ur manifold aswell?
go with a decent EBC and you will notice a difference. with a t-piece you cant factor in the boost drop off that usually happens higher in the rev range, EBC can factor all this in.
4000rpm/15psi is average for 230rwkw.
Are you sure the actuator on there is solid and holding the gate shut? A few GCG hi-flows suffered from this in the earlu day where the preload was not enough.
Do a dyno run with a boost plot. Watch what it is like and it will tell you if a decent EBC will help you. If the boost plot comes on nice and strong and holds boost to redline than atleast you know an EBC will not help you.
I agree that 4000rpm to hit 15psi on a highflow is a bit average.
Edited by PM-R33
Regarding tuners i have used both status tuning and chasers and their both excellent tuners. All i know regarding the actuator is that its the stock neo one. would this be creeping open? dont know what the standard tension is but have heard of people using 14psi actuators?
Ask trent what he thinks about it then. Im sure he has a big wealth of knowledge :blink:
take the vac line off the actuator and see what rpm you hit your target boost. then see what sort of difference there is between that and what it normally is
depending what the tune is like atm, more timing coming onto boost can make a huge difference. i've added more than 20degrees of timing coming onto boost on my car from where a "professional" tuner had it, car feels completely different
Due to potential danger of this IMO its a bit reckless to suggest it without mentioning how to avoid the risk, so you should add to that "back off a soon as you hit you hit 15psi, or you could potentially damage the motor". And maybe also what this will achieve - "if the boost comes on earlier then you have a boost control issue. ". Perhaps the OP knows these things, perhaps not.
I disagree. A PROPERLY SETUP EBC will work at least as well as a t piece, and should work better.
Nitrous Oxide! it will bring it on REAL quick!
3lt bottom end will too.
Port work and cams
Higher static CR
Better bottomend/off boost tuning
Cam gear adjustment
Ball bearing core and billet comp wheel
Methanol and a bunch of timing
Wire the wastegate shut
Bigger/better dump pipe and exhaust set up
Heavier right foot
Get a bigger actuator before you get an EBC.
OR
Live with it... you have to sacrifice somthing for more power.
check the actuator and preload
check diff gears (manual has different to auto)
check tune
check tune
check tune
did i mention check the tune? ignition timing plays a bit part in how the car performs and more importantly comes on boost
check basics, check base timing with a timing light and make sure its correct , ie sluggish timing makes the car perform low across the board
i assume you want more responsivenesss since the turbo has been fitted
so we can assume its not an actual car problem, but more of a tune related problem, since the new turbo went on
so either the turbo is junk or the tune is poor or both
Lol at least as well?? its $400 compare to $20 ??
if he has a boost holding issue it can also be an erray of things...
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
