4000rpm/15psi is average for 230rwkw.
Are you sure the actuator on there is solid and holding the gate shut? A few GCG hi-flows suffered from this in the earlu day where the preload was not enough.
its a auto running 15psi?!? what would you expect...
Looks like i might need to upgrade my actuator first and see how i go from their. I didn't get one when i got the hi-flow so if the stock one is only 5psi its probably not enough. I'll take it to chasers and see what they can do.'
Cheers so much for the help guys!
Power is a bit low, due to the auto which is normal.
loaded up on a dyno - same as a manual, so not 4000rpm for 15psi give the turbo.
much of a muchness when loaded up in regards to response
Another idea, bigger stall converter, not as easy as changing wastegate and wont bring the boost on before 4000rpm but it will get boost easier and make the car faster.
Nitrous Oxide! it will bring it on REAL quick!
3lt bottom end will too.
Port work and cams
Higher static CR
Better bottomend/off boost tuning
Cam gear adjustment
Ball bearing core and billet comp wheel
Methanol and a bunch of timing
Wire the wastegate shut
Bigger/better dump pipe and exhaust set up
Heavier right foot
Get a bigger actuator before you get an EBC.
OR
Live with it... you have to sacrifice somthing for more power.
Honestly I loved every single one of your ideas except for the live with it one :D I agree just get yourself a bigger actuator, say 14 or 16 psi and forget the dam boost controller for now. EBC is always better than manual boost controller :) It has lights and buttons :)
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
