grats on the car man! looks awesome :(
i had the difficult decision of 33r vs 34gtt... went gtt cause it was newer and i liked the style ;) (regret not having a gtr though!!!)
also like the way you write about the car lol, such poetry!
Congrats mate, very tidy specimin of a GTR. I know EXACTLY what you mean by getting a giddy feeling every morning when you wake up and get to drive to work, then drive home from work etc. Hell, it's not the best on fuel economy and just cost me $3200 in some repairs (don't mean to scare you off or anything hehe) but I prefer driving my GTR and my missus around rather than her drive me around in the Echo hehe. Hell, I am usually the first out the door and down to the shops during work if we run out of milk/coffee/something :cheers: I just love it to bits! (Travis you'd better be reading this too hahah)
All this, and I've owned mine since May this year. I've had some issues with it, but nothing you wouldn't expect from a 20yr old car, and nothing that has made me want to say "stuff this, I'm selling it...". It's a force to be reckoned with, they are bloody fast, very enjoyable and absolutely awesome value for money.
As for mods, I'd recommend what people have said thus far, that is go with supporting mods first. First major one being the exhaust, because the RB26 motors LOVE to breathe, and getting a larger exhaust will remove some restriction, hi-flow cat is a good idea aswel. Then start looking at things like ECU (you really want to get a full ECU solution like a PowerFC or the like, having multiple modules for different things is a tuning/troubleshooting nightmare), after that start looking into things like FMIC, injectors, adjustable cam gears and the like, but take your time and do it right.
-Chris
Congrats Karl, seeing as were telling you how to spend you hard earned heres my recommendation.
The first thing you should do with it is put an oil cooler on it and some decent oil...Redline is my choice, then go through the suspension looking for worn out gear.
Then do...
Apexi pods or if your worried about a defect go with an ARC airbox with a quality panel filter, they come up second hand a fair bit on SAU
Exhaust, front pipe and dumps,
PFC, timer and controller
Cam gears.
Dont worry about the intercooler until you go with bigger turbos
Then buy a beater/daily driver.
As already mentioned, there are plenty of places to spend money on a GTR.
There are some good factory bits on it already so you avoid needless cost and backwards stepping by leaving them in place. Things like the factory airbox (it's not a power restriction, so no gains changing it and keeps police happy) and the factory BOV's. The suspension on a stock R33 GTR isn't that bad and only a mild drop in height and mild spring rate increases are necessary for road use. There are some good suspension threads about setting one up for whatever you like but, factory stock they are an excellent handling car.
A good tip for you to keep the motor alive is to keep the factory turbo's at 12psi and avoid the temptation to blast them to 1bar/14.7psi. They die. And when they do they may like to give one of the piston bores some of the ceramic fragments from the exploding turbine. It's engine rebuild time. Easy to avoid however.
Up front, dropping all the fluids and changing them is a smart idea. I wager about 80% of the car owners on this forum have never changed diff or gear oil without there being a pre-exsisting issue. It's worth doing and according to factory reccomendations, just like engine oil.
Ah, also, how close is it to 100,000 now? Some very sound advice is to invest in a timing belt service. Take her to Xspeed if need be, they'll do one for $900, belts water pump etc whereas C-red will try and sting you for $1500 for the same job.
Get a good POD for a cool induction 'whoosh' sound.
Don't listen to this guy. :)
Edited by Tony de Wonderful
im not talking about race cars with specially designed air ducts, ask anyone with experience, pods on a gtr get heatsoaked very quickly as compared to the panel filter, u need to design a cai t o run pods but stock airbox with k and n panel filter is the best bang for buck wen u compare it to a 300-400 dollar pod kit
Convert it to RWD then it will be as chuckable and driftable as the GTST. :D
Do any race cars run stock airboxes?
If he wanted Rwd he'd buy a GTST
How certain can you be that pod > standard air pannel?
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
