Do any race cars run stock airboxes?
Plenty,
Including some of the hotter factory specials like the Nismo versions of the GTR of various flavours Z tune , R tune etc..
The mines R34GTR has stock airbox/ BOV, a lazy 600+ HP and notorious response.
Someone can try and tell people it doesn't sound good but, they will be seen as being faggy for saying so.
Why pay money for Pods when they are a step backwards in power on a GTR without a cold air box and feed?
Even with a CAI forking out over $500 to set it up nets you at best 2hp or so. It's what you call a good waste of money. $500 is better spent on something else.
Plenty,
I found this pixxor of an Mines R34 GTR replica.
Doesn't look stock to me.
I believe sav_man's 33 N1 which he ran Targa with is the stockest I've seen with just exhaust system done and ecu. Everything else is stock. Pushing more than 300rwkw with more than 95% duty on injectors. So yes it can be done but it all depends on what your objective is. For his, I think he just wanna keep the whole N1 version of the car as much as possible.
Councillor: Do what everyone suggested. My pick for exhaust would be Kakimoto Regu 06&R because of the very distinctive RB brumble they have (yes I've heard a few exhaust and by far, the Kaki's the most distinctive) and the "titanium" looking tip (if I hadnt got my Trust TI-R, I would be getting this). But if you prefer quieter ones, get the HKS Slient. The HKS one will be loud or sound good on high rev but on idle, its pretty docile.
Ultimately if you're not after high power, getting an ecu after the exhaust's been done is required. You will be amazed by how much difference a tune can do. Not so sure about the oil cooler though (its a good to have for street car imo, not a must have). If you need it, get it. If not, dont bother. I wouldnt have a clue because mine came with the factory oil cooler.
I'll say this, DO NOT get dumps for your GTR unless you're doing turbos too. The labour cost is ridicules if you're just doing dumps. And if you're not running really high power, its probably bugga all difference.
Targa rules say the intake system (including Injectors) must remain standard!. Also the car must run on a standard ECU, in other words you can change your ECU so long as when the scruitineers plug in the original ECU the car must run.
Ash
http://www.skylinesaustralia.com/forums/R3...-s-t301285.html
Looks like a good buy for 500bucks. Maybe look at that before sourcing something new.
Ash: Thanks for the info but yea, sav_man's N1's running very well for a stock car.
That particular car has plenty of 'similar performance mods' but, is actually a 'replica' meaning it's not built by mines. It has plenty of extra modified bits that aren't the same as the mines car.Although quick, It's slower than the mines car.
have a look at the vid link I posted and you will see the stock airbox. they even point at it for you.
There have been some back to back tests on the stock air box that prove it's not a power restriction.
They are a good thing from factory. I guess they have been homiligated for motoracing so the factory item must be good.
Ash
Yes thats what I heard. Thats why my advice to TS is not to do that many mods unless he's got plans for really higher power. Personally I feel after tuning, the car already is very quick and enjoyable.
Some good advice from a GTR owner.
On GTR's the 'bolt on boy' approach can see your car go slower and be less enjoyable to drive. Planning out what you want to improve carefully will see you get the best results. Always consider carefully the 'why' before handing over of cash. And it does take some time to filter out the good advice from the ordinary on these forums. It's worth it though. :D
Yea... work out whats a MUST have and what are the GOOD TO HAVE items. Most of the time I see people spending heaps on good to have items and its really make the car a money pit when you add everything together. Its like Macca's upsize, 1 dollar more you get more but ask yourself, can you finish it?
black rims on silver body makes me f....ckn yawn = boring as hell
Sound like a boost comment. If the owner likes it, I dont see a problem with it.
    • Unfortunately haven’t taken pics yet after it was finished. All the edges are hemmed nicely, just had to cut holes for the gear shifter and seat bolts and seat belt bolts in the rear. The molds seem like they’re done with steam and a layer of glue on the underside to hold a bit of shape but still soft enough that it’s a good fit when it’s all pressed down.
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
