The Cops Are Ramping It Up - Leave The Skyline At Home!
Ok fellas...cops have been told to up the ante so watch out!!
how so they are already pulling over everything with 4 wheels and a cannon zorst.. guna start going for the pushbikes too?
  • Replies 234
Ha ha ha...mate, soon you'll get defected for having rusty roller blades! :)
Or a screw
Of which btw - we are all still waiting to see the defect notice or whatever with a screw listed on it - as you said.
Or a screw
HA AHA HA
The second and third fines was just a fine letter saying $292 for driving a unroadworthy vehicle. That's the problem. Nothing listed. Why do you think I lost it?
It's because I still have a valid roadworthy and just cleared it a few weeks before and then they fine me again.
Rubbish - every canary i've had lists the items that are unroadworthy.
How can you just say a car is "unroadworthy" without specifiying what needs to be fixed?
I think we busted that mystery.
it sounds like he got the fine they like handing out not actually a defect my mate got one a couple weeks ago for too low but no defect just infringement notice.. which is stupid cos he doesnt have to show anyone that the car has been raised etc.
can someone clarify does the defect notice need 5 items for a major? someone told me this and i find it hard to believe i got 2 things listed and "inspection incomplete" which vicroads had never heard of inspection incomplete..
:banana:
:banana:
one big enough flaw will give you a major if the Office sees it as a safety issue, IE; tyres on belts. it is up to the officers discretion.
If that's the case, keep the RWC and the fine.. don't pay it and take the matter to court. How can you be fined for driving an unroadworthy car without being told what is unroadworthy on it?
Exactly.
You cannot defect a car and say it is Unroadworthy - without actually stating what the problem is.
That is just retarded.
in the last week, i've only seen 2cop cars. whats the big deal with everyone ? your car is a magnet, leave it at home,
if its legal to the eye, no problems.
thanks for that..
maybe it would be nice to go for a drive given the good weather
i agree nismoid but that is what they are doing just handing out $292 fine as an infringement notice.
I would definitely contest all of these fines. If they don't NOU the car I don't see how it's possible to issue fine for Unroadworthy vehicle. Any decent solicitor should be able to get you off that if you ask me. Roadworthiness is a safety issue so fines irrelevant IMO as NOU is to force person to make car safe. I fyou give out fine without NOU then your defeiting the purpose. Doesn't make any sense to me and I would think court would agree.
Ash,
Please read my posts again. I got a canary initially - yes, of course I got all the yellow sticker and the list of things to fix - yes. However, the subsequent fines did not involve a canary. You may recall that I wrote, I can't believe they can fine me again for having an unroadworthy vehicle and $292 only days after I got a full RWC and had cleared it with Vicroads.
This is why I am upset. So to recap, canaried - cleared it, then fined again after that without canary.
Exactly.
Thank you...now you feel my anger...the pointed to various things as I had mentioned before and then just said it's unroadworthy even after I showed them my RWC I got a few days before that.
thanks for that..
+1
Guest
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
    • @Dose Pipe Sutututu I read your replies RE: R35 GTR MAFs, any ideal spots to put on? Obviously will need the adapter plate. Will be having a cross over intercooler fitted shortly, would putting it a bit before the TB be okay?
