RB25 and RB26 squish pad removal adds a LOT of extra volume to the combustion chamber, yet when I see this recommended or suggested I never see any mention of how the compression ratio is brought back up to a sensible level. Off the shelf pistons seem to be used and a 0.9 mm head gasket is as thin as any I have come upon. So what CR are people getting with a full squish pad removal, and how are they achieving a figure close to stock? I am not asking as to why the practice is recommended or discouraged on the vasis of combustion, I am purely interested in how a sensible CR is achieved once they are both gone :cheers: Thanks.
Yeah they get a compression of 9.0 (static) or thereabouts with their roller wave pistons... could a company like CP custom make pistons to suit a modified combustion chamber with squish pads removed?
someone want to go a little further into detail? could be a very usefull thread if how removing squish pads effects CR was added in somewhere.
IE the squish pad is X and removing makes the head sit closer/further to/from the block thus giving higher/lower CR.
as people like me would like to know more about the little terms they have heard without making new pointless threads.
Thanks!
seems to be only used on full tilt motors. ie massive boost and high rpm. ie said motors arnt required to have "as much" torque down low (ie big turbos) so the lower comp whatever it may be, is not at the front of the line in the engines purpose.
hope that sheds some light. ie: street. no pad removal,street/race, exhaust removed, full race, both removed.
would be a nice trick on a rb30 using 25 pistons and asociated block decking having a full tilt head still with 9 or so comp.
exactly the same as my experience. the guys that do both sides and full tilt heads are not worried about the loss of static CR as they are making up for it with big timing numbers and LOTS of BOOST. so the short answer is they just live with the lower static CR as the other benefits they get is what they are after. and the rule of thumb is the same as what I've seen/used too. street = standard, street/race exhaust side gone. full race both sides gone.
apparently the endyne stuff is kick ass. I would like to try one of their heads and roller wave piston set-ups one day....
but when it come to engine combustion chamber/cam set up, its all abit of a black art in this country, only japan and usa seem to be openly sharing there r and d on the net..
Yeh I agree with you there. Sucks but I guess that is what they need to do to stay ahead of the game. Not like they can patent it haha
  • 3 weeks later...
it's the same with everything. especially the USA. they love to share their developments etc on the net, and people can easily learn from it. here in aus people keep stuff much closer to their chest as they don't want competitors learning all their secrets. :(
not me...i tell all...thats what this place is all about.
some food for thought...lowering the static comp allows more charge to enter the combustion chamber. The more charge the bigger the bang.
It works well in our own engines....remember a boosted engine the cylinder pressure is multiplyed than would otherwise be seen if it was atmo as the air is being rammed in and not pulled in under vacuum.
Edited by DiRTgarage
How does that work? I would have thought the effect of static CR would be negligible on cylinder filling as the piston wont be anywhere near TDC when the inlet valve is open - right?
There is no real doubt that street = stock, race = exhaust removed, full race = both
When in the US we did this to a few high HP mitsubishi's, but each time we used a custom piston design for open camber usage.
What effect do you think using the regular style RB piston which is clearly been design for quench pads has on maintaining the correct swirl and fire path?
Yes a correct setup will be a lot less likely to detonate due to the open chamber, but in the real world where the 2jz can make 1000hp+ on the stock quench padded head (near identical in design to the RB) is it somthing that is really worth while unless the vehicle is a fully dedicated race car that really is pushing the limit? I know I wouldnt bother
yeah agree on that point. and yeah there are still lots of good smart guys in aus who share stuff too. but just in general aus workshops play things much closer to the chest and don't want to give away hard earned knowledge/tricks etc. which is fair enough. it seems in the US their desire to show how smart they are overtakes the desire to keeps things secret! which is good. :)
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
