Some items i have that no longer use. All parts in just west of Brisbane near Plainlands
RB25 Ross Tuffbond balancer bought for my 26/30 when it was going into my 4 door 32- changed my mind and put into a GTR- power steering alignment is different.
This has done around 10 minutes on the engine on initial start. So if you want a new-as-can-get this is for you. $450+postage over $550 new
I am after one for a 26!!
Volks Te37's 17x7.5+40 17x8.5+40
I bought these new back in 2005 when they were around 1k per corner. Had them on my 180 with 10mm spacer on the front to clear the skyline brakes.
They are fitted with semi slicks which would have enough for 1 more track day. One of the fronts is flat spotted to the metal so unusable.
Great lightweight rims Great condition, the odd mark from removing and refitting tyres, no gutter rash
$1800+postage
This is what they look like on my 180
Clutch Suit RB20/25 This was for the above engine. But didn't quite have the clamping load for the torque. Its very similar in spec to what i run in my RB25. That has 430rwhp, has no issues with that power.This clutch has been rebuilt and ready to slot in!!
$500+postage
Enkie's These are 16x8+32 16x7+35
Super lightweight - Fitted with Dunlop semi slicks that have seen 1 track day on a stock powered 32 Skyline. They are in great nik with heaps of tread. These i bought new from Queensland Raceway and cost $1000 alone!! Tyres are 205/50/16 Yes there's only3 in the pic, there are 4 however :cheers:
$1500 + postage
Nismo engine mounts for RB26 This are brand new, never fitted. $400+postage
Edited by Simonster
Any idea what Brand and hp rating the clutch is, I'm looking at up to about 500hp atw and it will get a good work out.
Edited by W0rp3D
No brand, the hp rating is a bullsh*t number anyway, it's all about torque. It has a clamping force of 1210kg. Its says 1350kg on the pressure plate but that is inaccurate. Had it tested by my clutch guy in Lismore-NSW. I know it won't hold 600ft/lbs because thats why i had a new one made :down:
I can ask him to to work it out, if you want to know a hp figure?
  • 2 months later...
Volks now $1400 yep, $1400 for 17 inch volks guys. come grab them
205/50/16 Semi slicks price drop to $400, come on guys this is a stupidly low price!
Enkie's 16 inch rims now $400, supercheap for super light track rims.
    • The Neat gears use an alternative profile, no? Something different to what normal OEM stuff is. Is the noise at all traceable to that? Reason I ask is that my CW&P are effectively past their use by bate and Neat is the obvious option.
    • Just picked up my first skyline. R34 4 door with an rb25det and manual swap. I’m in the US. It has a bunch of issues but the problem I’m chasing now is the indicator, hazards, and horn do not work. I took out the indicator relay and fuses and tested separately and they seem to be working fine. When I activate the turn signal stalk or the hazard button nothing happens, no clicking, and no dash lights. Same with the horn. What should I test next? The headlights, taillights, and brake lights work fine so I think the stalk is good.
    • RD25 neo... sorry bad joke ill see myself out
    • Sorry just googled Toyota WiLL Vi and wish that I didn't, day ruined, fark etc.
    • So mines not in yet ... which should tell you something ...   I got a set of neat gears as well, took a year to get those. Then the setup was a real tricky one, with all the changes. It seems the shims for the front diffs are in short supply and had to wait two round of custom ones. This was all done by a professional diff builder , not me/diy.   So here we are about to go into 2025 and I do finally have a built front sump / diff / gears.  Just need the mojo to pull out the engine ...   Oh as an aside on the neat gears, they have some whine, mostly on decel. Taken a bit of setup again to get that down to a street car level.
