Well i normally post in the BMW Projects topic on Eurocca.net (http://forums.eurocca.net/showthread...=17736&page=15), and regularly poke around on SAU for hints and tips for my RB26'd BMW, so it's nice to get creative on something a little different.
My father in law owns a cabinet making business, so one day we decided to start making my 2 year old son's christmas present.
The theme is "Lightning McQueen" from the pixar movie "Cars".. and my son's favourite character. McQueen is a bright red C6 Covette built for the racetrack.
The bed has been CNC routed from MDF, and all edges rounded with a hand router. The wheels are sandwiched pieces of MDF (thicker tyres on the rear of course!!) and have even been installed with ball bearings as my son loves to spin anything with wheels.. i guess he gets that from his dad!
Once constructed we painted the entire bed in 2 pack red base coat, then masked off the areas where the lightning bolt is and painted those areas in yellow base coat. Then we layed down the pinstripe around the edges of the lightning bolt and sprayed 2 pack clear over the entire thing (this way my son won't be tempted to try and peel up the pinstripe while he's lying in bed).
My wife grabbed some stickers from the internet and printed them onto label paper and cut them out by hand.
There's about 30 hours in this bed and hopefully my son will fit in it for a few years before we have to think about doing another one! me thinks F1 theme next!!
post-30449-1261439013_thumb.jpg post-30449-1261439023_thumb.jpg post-30449-1261439037_thumb.jpg
post-30449-1261439051_thumb.jpg post-30449-1261439067_thumb.jpg post-30449-1261439081_thumb.jpg post-30449-1261439102_thumb.jpg
https://www.sau.com.au/forums/topic/301030-c6-corvette-with-a-twist/
  • 1 year later...
    • Somehow we've reenacted this video completely seriously:
    • Nistune is pretty easy if all you want to do is change the injectors. TIM + latency change will do it. But I am very skeptical your mechanic has actually diagnosed the issue. As others have said flow/function test your injectors.
    • ^This. If you have to do injectors, and you have to buy bigger ones, get the smallest Bosch EV14 based injectors of the correct length that you can. This will be about 500-525cc most likely. The stock ECU (with Nistune) will be fine to run those. Then, use a Nistune. Tune it yourself. If all that you are doing is changing injector size, then you literally only have to change one number to do it, and then maybe some fine tuning of that number. You will not need to touch the fuel or ignition maps at all.
    • I don't know what those pipes are, but I'd say there is a good chance they are old school Japanese tuner because they are equal length and nicely made. Maybe someone like @Rezz who has direct access to japanese history might be able to help. Even so, I'm not sure what inspectors could check it to, they presumably are googling 30 year old japanese stuff same as us.
    • Yep he is an awesome bloke, we work together on that car. You will have fun at the 6hr, Tony doesn't stuff around when he goes racing does pretty well.
