R33 Parts. Front Bars, Coil Packs, Bov, Seat Belts, Throttle Bodies, Rims Stock R33 And 4stud Aftermarket
Stock Front Bar R33 (no reo): SOLD
Stock Rear Bar R33: $70
Fibreglass Front Bar M-Spec like (no reo): - SOLD
Stock BOV and crossover pipe: $10
Stock front seat belts: $15 each
Stock intake plenum: $40
Stock R33 Throttle Body: $10
Stock 240sx Throttle Body: $10
Stock series1 coils: SOLD
Stock R33 rims set of 4 (2 have very poor rubber on them and 2 without rubber) : $90 set
Set of 4 stud 114.3 rims set of 4 with rubber: $300 set - will suit 180sx/silvia etc.
Stock bonnet with hole cut in it: $20
Aftermarket fiberglass bonnet: $130
Prices negotiable and postage at purchasers expense.
Post a reply, private message, email to [email protected] or ring/sms on 0423 051 961.
Cheers
Stock Rear Bar R33: $50 (PRICE DROP FROM $70)
Stock intake plenum: $30 (PRICE DROP FROM $40)
Stock R33 rims set of 4 (2 have very poor rubber on them and 2 without rubber) : $75 set (PRICE DROP FROM $90)
Set of 4 stud 114.3 rims set of 4 with rubber: $300 set - will suit 180sx/silvia etc. (Rubber and wheel weigh 16kg each)
Aftermarket fiberglass bonnet: $100 (PRICE DROP FROM $130)
Location of items Petrie, Brisbane, QLD 4502
Cheers
I'll take the above. Have money here ready to go
I'll pass on the rims, found some 15's that are 14kg each with tread
send details to
[email protected] (i can access this email at work and do funds transferrs etc)
Stock BOV and crossover pipe: SOLD pending payment
Stock R33 Throttle Body: SOLD pending payment
Stock 240sx Throttle Body: SOLD pending payment
Cheers
Cheers
Cheers
  • 3 weeks later...
 Share
    • Hi All Finally getting back to work on the R32 this weekend and had a quick question about the GKTech anti squat kit (https://au.gktech.com/products/s13-180sx-r32-subframe-anti-squat-reduction-weld-in-kit?_pos=39&_fid=eb6b5077e&_ss=c) So, this straightens out the rear LCA and increases the roll centre by 20MM which is great BUT I also have MFR roll centre adjusters (https://www.rhdjapan.com/moonface-super-lap-rc-joint-roll-center-adjuster-bnr32-ps13-rps13.html) which gives a +15MM lift. My question is whether they can/should be used together or if its going to massively effect the geometry? In my mind, I can't see that they work together but was hoping for some feedback on someone who has done this before deciding which to use or if both?   Thanks
    • Agreed. Thing has to be running absolutely pig rich as well. I would worry a lot less about your idle and start going through all your electrical before the car burns down.
    • Before and after of reflectors, two coats brushed on. i used a bucket full of hot water to to heat up glue, then pry the lenses out a little with a flathead screwdriver and cutting with a Stanley. I’m not sure how the paint will go but it’s my best chance without dipping.  see the reflection in the picture I’m pointing? That’s two coats paint and you can see the state of it in before shot after I cleaned it
    • roll and pump rear guards = you'll be fine mate
