hey guys
with the xmas break being on ive decided to retrofit some projectors into my R33.
couple of questions:
1. what projectors would best suit R33 headlights? ive read that lexus ones are good but what are the best for a better fit into the headlight casing? (s2 r33 if that makes a difference)
2. do hid kits come with just the normal beam lights? (as in do i need another kit for hi beam? i really need a general explanation on what hid's are and how they beter)
3. has anyone done this before? (ive read post's on people thinking about doing it and ive seen a youtube video on someone doing it but has anyone on here actually done it
cheers
https://www.sau.com.au/forums/topic/301060-r33-projector-retrofit/
I know someone on here recently posted doing the headlight change, check through this list of forums it'll probably be about page 4-5 now most likely...has photos and looks decent to, forgot what projectors they used
personally, id be wary.. id be worried about stuffing up the angle at which i install the lenses.. the way the projector lense works is it focuses the broad light given off by the HID globe to a specific angle and direction... obviously you can see where you can easily go wrong. without the lense the HIDs are horrible.. super bright but hardly lights up the road.
ive only been in one car with a good set of HIDs to be honnest.. my mate has a JDM evo 8 with HIDs..
They were marginally better than my narva +50 globes i was running in my evo 4. highbeam was no better, and i think i would have rathered the globes anyway... those narva +50 globes are seriously something to consider before butchering your headlights... and if thats not enough try a new relay for your globes :P that always works well
arent these a h4 though? and the r33 only takes h1's?
Another option - if you can afford the coinage,...is to buy a pair of R33 GTR S3 lights and plonk them in...they come with Zenon projectors...looks freaken tough...do a search. I actually posted a whole thread on my search for these a while back.
I got mine from repco and they are available in all the different globe types, h4 h1 etc.. will set you back $50 tho
yet agree on the S3 GTR headlights.. just not sure if they fit up or need to change pannels? plus they are bloody exxy haha
heres mine :) so much better than silly standard looking beams.
hey mate
that looks awesome,
what projector did u use?
and how long did it take u to do both headlights?
it a b**ch of a job?
  • 1 month later...
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
