Patrol L28 Into C210
Hey Guys!
The L24 and auto in my white sedan has finally kicked it in.
So i got a l28 out of a patrol to put in it.
Now i need to change the sump and oil pick up to the l24 ones, but what do i do about the dipstick hole? just drill a new hole in the block?
Does anyone know if i can use the patrol clutch on a rwd gearbox?
Part numbers are different.
What gearbox can i use, im guessing c110/c210 ones are the same, but r30 ones are shorter? how about bluebird ones?
Gordie, I've got the L28 in mine. I have a tube/sleeve welded onto the side of my sump that is partly inserted into the sump. Works fine. Can put up a pic up if you want. You will need to extend the oil pickup to suit the oil basin, also not to hard.
As for gearboxes, the 2 mentioned are fine and any Z box will probably work.
Hey Gordie,
This is what they did to my F54 block re the dipstick. You can drill the block as it will look more original, as there is a flat that is where it goes. It's not an easy drill out, but still possible, as a few here have done it. If your going to drill the block, you have to be sure to blank off the rear oil pick up gallery just to be sure.
Cheers, D
As for the clutch, I'm not sure, but doesn't the Patrol clutch operate in the opposite direction as our L24 clutches do. I think your best served buying NEW clutches, as opposed to using secondhand, purely for the work effort needed to get them out once in the car. For a lousy couple of hundred dollars you can get a very good clutch, just make sure it's the right diameter. 225mm is the common for L24 & L28, but a 240mm option is available if you have the flywheel to match.
Cheers, D
Cheers, D
Patrols are a push type clutch too. the one on the motor is only 1000k's old so would like to use it if possible. if not il just get a new one.
only differance in the clutch kit part numbers are in the pressure plate.
Got a better pic of where the dipstick goes though the block?
Forgot to mention the L28 oil pickup point is in a different position. When the L24 forward mounted oil reservoir sump is attached to the L28, it's to short as the L28 has a midway oil reservoir. It's no big hurdle.
 Share
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
    • Well, yeah, the RB26 is definitely that far off the mark. From a pure technology point of view it is closer to the engines of the 60s than it is to the engines of the last 10 years. There is absolutely nothing special about an RB26 that wasn't present in engines going all the way back to the 60s, except probably the four valve head. The bottom end is just bog standard Japanese stuff. The head is nothing special. Celicas in the 70s were the same thing, in 4cyl 2 valve form. The ITBs are nothing special when you consider that the same Celicas had twin Solexes on them, and so had throttle plates in the exact same place. There's no variable valve timing, no variable inlet manifold, which even other RBs had either before the 26 came out or shortly afterward. The ECU is pretty rude and crude. The only things it has going for it are that the physical structure was pretty bloody tough for a mass produced engine, the twin-turbos and ITBs made for a bit of uniqueness against the competition (and even Toyota were ahead on the twin turbs thing, weren't they?) and the electronic controls and measuring devices (ie, AFMs, CAS, etc) were good enough to make it run well. Oh, and it sounds better than almost anything else, ever. The VR38 is absolutely halfway between the RB generation and the current generation, so it definitely has a massive increase in the sophistication of the electronics, allowing for a lot more dynamic optimisation of mapping. Then there's things like metal treatments and other coatings on things, adoption of variable cam stuff, and a bunch of other little improvements that mean it has to be a better thing than the RB26. But I otherwise agree with you that it is approximately the same thing as a 26. But, skip forward another 10 years from that engine and then the things that I mentioned in previous post come out to play. High compression, massively sophisticated computers, direct injection, clever measuring sensors, etc etc. They are the real difference between trying to make big power with a 26 and trying to make big power with a S/B50/54 (or whatever the preferred BMW engine of the week is).
    • Is the RB26 actually that far off the mark? Honestly from where I'm sitting a VR38DETT is not actually that much more advanced than the RB26. Yes, there is a scavenge pump on the VR38, it's smarter in a number of ways but it's not actually jumping out to me as alien technology. Something like a B58 or V35A-FTS on the other hand has so many surprising little design features that add up to be something that just isn't comparable.
