Patrol L28 Into C210
Hey Guys!
The L24 and auto in my white sedan has finally kicked it in.
So i got a l28 out of a patrol to put in it.
Now i need to change the sump and oil pick up to the l24 ones, but what do i do about the dipstick hole? just drill a new hole in the block?
Does anyone know if i can use the patrol clutch on a rwd gearbox?
Part numbers are different.
What gearbox can i use, im guessing c110/c210 ones are the same, but r30 ones are shorter? how about bluebird ones?
Gordie, I've got the L28 in mine. I have a tube/sleeve welded onto the side of my sump that is partly inserted into the sump. Works fine. Can put up a pic up if you want. You will need to extend the oil pickup to suit the oil basin, also not to hard.
As for gearboxes, the 2 mentioned are fine and any Z box will probably work.
Hey Gordie,
This is what they did to my F54 block re the dipstick. You can drill the block as it will look more original, as there is a flat that is where it goes. It's not an easy drill out, but still possible, as a few here have done it. If your going to drill the block, you have to be sure to blank off the rear oil pick up gallery just to be sure.
Cheers, D
As for the clutch, I'm not sure, but doesn't the Patrol clutch operate in the opposite direction as our L24 clutches do. I think your best served buying NEW clutches, as opposed to using secondhand, purely for the work effort needed to get them out once in the car. For a lousy couple of hundred dollars you can get a very good clutch, just make sure it's the right diameter. 225mm is the common for L24 & L28, but a 240mm option is available if you have the flywheel to match.
Cheers, D
Cheers, D
Patrols are a push type clutch too. the one on the motor is only 1000k's old so would like to use it if possible. if not il just get a new one.
only differance in the clutch kit part numbers are in the pressure plate.
Got a better pic of where the dipstick goes though the block?
Forgot to mention the L28 oil pickup point is in a different position. When the L24 forward mounted oil reservoir sump is attached to the L28, it's to short as the L28 has a midway oil reservoir. It's no big hurdle.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
