My old 33 didn't have one in the 4 1/2 years I owned it & I didn't have any issues, I just left it idling while I sorted my shiz
+1
My car doesn't have one & haven't had any engine related problems with the 2.5 years I owned it. I use my watch for the 15 to 30secs timing :P
i think the reason its illegal is because it is then an insurance liability, walk away with it on someone jumps in you claim...all coz ur silly, that way it being illegal you cant claim= same money for insurers... im just assuming here
Rest assured your assumption is incorrect. Have you ever tried to turn your steering wheel without the key in the ignition? Doesn't turn very far does it... good ole steering lock
I've often wondered about the underlying issue though as from what I remember there are certain turbo diesel 4x4's etc which actually have turbo timers from factory. My turbo timer is an integral part of my immobilizer, and one of my buttons on my remote turns the motor off by remote. A lot of grey area here indeed.
Front facing vents that aren't factory fitted need to pass criteria, and CAN be illegal.
Same with mascots, bonnet pins, etc ... anything that could be dangerous to somebody if they were hit by your rice rocket.
Guys, read the ADRs and VSB documents - don't just take a stab in the dark and dribble shit. This is why you all get yellow stickers.
Yet you still see 4x4's and utes with massive steel gates on the front.
If they are supposed to stop the car getting damaged by cattle and roos, what are they gonna do to pedestrians etc.
But I guess it's ok since they are not carbon fibre right? lol
Like I said...criteria...go and do some reading.
Let me do it for you.
Start here:
http://www.infrastructure.gov.au/roads/veh...etin/index.aspx
VSB14
-> BODY MODIFICATIONS
--> SECTION 4.1 + 4.2 (BONNET SCOOTS AND PROJECTIONS + BONNET PINS + MASCOTS)
I'm amazed the old WRXs arent illegal considering that writeup. They look like shit and are dangerous to both driver and the poor people they hit.
Hahahaha how many F*CKING DEFECT TOPICS DOES THERE NEED TO BE!!?!?!?11???
Seriously, all of you just stfu about it. c*nt got defected because his car has defects. yeah, cops were douches to him. cops are douches to all young people with more-than-a-getz-spec performance...
except for cefiro drivers. because we're f*cking awesome like Sam Elliott.
Yeah they look retarded but so do WRX's anyway. :)
Apparently they need them 'cos of the top mounted intercooler though?
    • The jack pad placement always had me scratching my head. I only have a small section to work with on both the E90 and E70 (and insert new project car here ) and I could see lining it up to be a bit of a bugger. For me, the E90 is just too low and needs small ramps and then the front centre jack point is a bit tricky to line up (it's half way down the subframe and about the size of a tennis ball, its really hard to see unless your head is on the ground), so I definitely like the idea of not having to do a multi-stage jack and just sliding these bad boys in under the sides. There's only one small point at each corner, so I can't jack AND add a stand on the same corner. Or, maybe I can and I'm too nervous to try. 😟
    • Is this not the biggest deal of all? I was hoping the whole "will slide under cars with skirts etc and lift evenly quickly with minimal fuss" was the entire point of such a device?
    • Here's Neil's car up on mine recently
    • Yeah I've got one of these, Quick Jack not Quick Lift, but your link looks like a good copy For me, it's better than no hoist, but it is definitely not as good as a hoist  It lifts the car about 60cm which is a nice working height compared to regular stands and it is only under the sills so it doesn't get in the way like regular chassis stands do.  No need to use regular stands, it has a safety lock on it. On the down side it is really heavy/unwieldy to drag into place, and you have to place it after the car is there (no option to drive the car to where the frames are. You need to try and line it up with the proper sill points which is hard as it swings up in an arc and there is surprisingly little adjustment in the distance between the rubber pads for different car lengths. Not a big deal, but in practice a jack + stands is probably quicker. Also there are hydraulic lines to each side and you need either a 240v or 12v source to power it depending on which option you have, I use 12v as I always seem to have a battery around.
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
