Hi Butler
Mine is for sale (thanks fane/Cam) . As Fane said its more than you stated that you wanted to pay, but most of the grunt work is done. Practically no maintenance work left to do apart from regular services.
Not sure if it was you that sms'd me yesterday ?
A link to the car details is in my signature below
cheers
Avram
https://www.sau.com.au/forums/topic/30107-wtb-32-gts-t/#findComment-612722
Jarrad - getting an R32 with less than 100,000kms on it may be more than just a little optimistic. Have a look at Rasclaat's (spelling?) which is in the for sale section.
Mine had done a genuine 74,000 when i got my r32. You can tell because of the general condition of the car. It was immaculate inside and out. PLus the fact that the car yard was asking 24k for it.
So yes you can find them but most of them will be over 100k's now.
https://www.sau.com.au/forums/topic/30107-wtb-32-gts-t/#findComment-612907
how long ago was that tho r32-gts?
imports have low ks for 2 reasons...
the taco wind back...or the guy in japan hardly drove it because it was easier to catch the train around the corner...
a car that is 10-14 years old should have more than 100k kms on it and if it doesnt and its real then you should buy it because it has been babyed...
like r32-gts said you have to judge it on the interior of the car and probably a leak down test... :)
goodluck with the purchase... :)
https://www.sau.com.au/forums/topic/30107-wtb-32-gts-t/#findComment-613025
im semi-sorta-semi-not-really-but-semi thinking about selling my car.. (whatever that means)
R32 GTST very good condition
1993 type-M with 84k kms
(real or not im not sure but bought it at 80k kms)
its basically stock cept for:
cat back exhaust
mines chip (deleted 180kph/ not sure what else)
and apexi turbo timer
laserline alarm..
So why am i putting this.. i guess if u give me a real dam good price i may seriously consider selling it...
https://www.sau.com.au/forums/topic/30107-wtb-32-gts-t/#findComment-613357
    • You guys need to live a little! Nothing keeps the blood flowing like lying under something that could collapse on you at any time! The vast majority of the weight of my car is out of it. There's zero attached outside of the interior of the car. It's pretty much full interior but once I take the front seats out it's just the dash and some of the boot contents remaining. I would guess that as it sits it would be already well under a tonne, even less without the seats.
    • https://www.youtube.com/watch?v=KyZDvZmvhik
    • You'd be better off digging a pit and standing under it to shoot it.
    • The easiest way would to be ignore the oscilloscope, grab a multimeter, and make sure all the main connections are right. An oscilloscope will give 99.9% of even technicians so much grief, as they have no idea what things should even look like on an oscilloscope. Which is also even more likely for someone who's first ever major work on a car is this If the battery volts are dropping down so low, the LDV will reboot the ECU, when it does so, it will drop out the start circuit. If this is occuring, the battery voltage should also come back up. Give it a few tests, even simple ones like when you're attempting to crank it, measure voltage from the engine block, to the negative terminal. You might find you've got really bad connections somewhere. My guess is the "new" motor has something like a shit starter motor, at which point, you can swap the starter motor from the old motor, to the new motor. Before I did any of the above though, I'd 100% confirm the battery in the vehicle. Most jumper packs are absolutely useless, especially if a battery has a bad cell for example. Also the new modern "jump packs" if you don't know what you're doing with them, you won't even get them into high current stage. So go back to basics, check the battery, especially with a known good one as a replacement test. Check ALL the wiring, this includes where they're bolted onto the battery, and bolted onto the starter motor. Check all the earth straps are on. Measure your resistances across your earth straps. A good check here is to measure voltage across the earth straps while you're trying to crank it. If you're seeing voltage, you've got high resistance joints! Oh, and once you've done the above, check the battery over again.
