Hey guys Posting this for a friend.
Car has fully built motor an alot of TLC has gone into this car so grab youself a bargain.. Josh has receipts for $27g+ for this car an previous owner spent $$$$ aswell.!
Car is in PERFECT condition.!
ADM 2001 S15 Spec S 6spd
Rego till August 2010
Motor was built at 107000kms by POWERTUNE(sr20 Specialist in Sydney) and have all receipts.. speedo now reads 112000kms so 5000kms on built motor. turbo kit has about 2500kms on it.!
This car is not Daily driven its lucky to get driven 4times a month.NEVER tracked or drifted
Mods Below:
Engine Mods
SR20DET, MOTOR TUNED/BUILT BY POWERTUNE
CP Forged Pistons 8.5.1
CP Rings
Eagle H-beam conrods
ACL race main bearings
ACL race conrod bearings
Thrust bearing
Endurotech timing chain kit
Cosmetic Head Gasket
ARP Main studs
ARP head studs
Lifters
BC Valve springs + retainers
BC Stage 2 Cams 264°/264
Fidanza exhaust cam gear
Gktech Rocker Arm Stoppers
Nissan rear main seal
Nissan valve stem seals
Nissan water pump
Cooper Fuel filter
Ryco oil filter
Apexi Power FC w/ hand controller
Garret GT3071r.64
Tial 38m External Gate
Screamer Pipe
Braided water and Oil lines off the turbo with Walbro fittings
POWERTUNE low mount Steam Pipe exhaust manifold Ceramic Coated
XFORCE dump (heat wrapped)
Hi-Flow Metal Cat
2 1/2'' Turbo back XFORCE Titanium exhaust
XFORCE Twin tip Muffler
700cc Injectors
Hybrid FMIC
GFB Stealth BOV(Can be plumbed back or atmosphere)
Splitfire coil packs
Z32 AFM
Apexi Power Intake Pod Filter(in enclosed box)
Nismo 400 Hp fuel pump
Greddy Blue Hose fittings
Odyssey Dry cell Battery
Nismo Oil Cap
Greddy Air Diversion Plate
Engine Dampener
Rocker cover sprayed Blue
Motor has had the treatment:
Reconditioned, Bore & hone , Deck block
Grind crank
Deck cylinder head
Exterior
Brilliant Blue Paint
Full vertex kit
Jap spec badges
Nismo clear indicators
Rear Origin Style Tailights
Removed wing
Debadged boot lid
Interior
BRIDE Gias3 Low Max Carbon kevlar seats
BRIDE (LR) Seat Rails
Nardi 330mm Steering Wheel
HKB boss kit + D1 Blue Quick Release kit
Greddy white faced boost and oil pressure gauges in centre air vents
Splitfire A/F Ratio Guage in cup
Greddy profec b type s boost controller
NISMO Racing Pedals
Quicktrack Alarm with turbo timer built in
Pioneer AVH-P5050 TV/DVD player w/usb cord an remote.
Hertz Speakers
Soundstream 1000w 5CH amp
12'' Sub
200sx Floor mats
Wheels & Suspension
18x9 18x10 Volk Top Secret GOLD GTC
Falken stretched tyres front an rear
Apexi World Sport Coilovers
ISC rear camber arms.
Whiteline front strut brace
Alloy Subframe Bushes
Brakes
DBA Slotted and Dimpled Rotors (front),
Braided Brake lines
EBC Green stuff Pads
Driveline
S15 6-speed
6-speed short shifter kit
5 puk sprung brass button clutch
Standard Diff.
Car now has no leather trim in it.. has BRIDE carbon Recliners, standard backseat and will include 3m of bride material with sale to trim backseat an door trims, aswell in the sale Vented Fibreglass bonnet and midnight mods 19row oil cooler with inline thermo with relocator.
Price $34000ono Regoed(NSW) till August 31st
ANY INSPECTIONS WELCOME..! NO TEST PILOTS,TYRE KICKERS..!
Car Makes 273rwkw on 1.5Bar If you want 300rwkw+ strap a GT3076r on and you shall recieve.!
OPEN TO OFFERS BUT NO LOW BALLING...!!
Located in Newcastle NSW
Reason for sale: Wanting a AWD car.. 34GTR, Evo
PM ME FOR MORE DETAILS..!
^^^ DOESNT HAVE LEATHER INTERIOR NOW HAS BRIDE CARBON RECLINERS ^^^
Edited by karbonphyber
https://www.sau.com.au/forums/topic/301101-built-2001-adm-s15/
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
    • Update 1: I did some work on the car already before finalizing this post and my "issues" list. I dropped the Tomei exhaust in favor of the HKS Hi Power Silent. Sounds nice and I can actually hear myself think now. Also gives me a realistic chance to legally drive without silencer inserts. A bit of cheating was necessary to still be able to mount the Top Secret style diffuser. Some malusage of washers and a bit of "convincing" toward the brackets and exhaust hanger seemed to do the trick. The shaky steering wheel has been resolved as various suspension components were worn, like sway bar bushings and link bars. Most notably the two steering tie rod ends. Had some trouble finding bushings because my sway bars are not OEM thickness, 23.x up front and 27 rear. But non adjustable, so no aftermarket I suppose. Maybe they are nismo units? Turbo oil drain hoses were definitely still the originals and are new now. Wasn't the cause of the turbo oil leak sadly. Currently removing the rear turbo because of it, I suspect the braided oil feed line is the culprit. This issue needs to be dealt with so I can work towards actually getting the turbo setup legal and inspected. Two new issues to add to the list as well. Rear Main seal is probably leaking. Time will show how bad it is, I don't really want to drop the gearbox right now just for the stupid seal. Could fix a few other things in one go once I do that. Front right driveshaft grease is going past the cv boot, so at some point I'll fix that too.
    • Ok so no 4cyl clutch... Yeah it is a factory manual. So if iam correct i need clutch and flywheel too? I can use something that suits something like R32 GTST?   EDIT: https://www.ebay.com/itm/224291042776 Is this ok?   EDIT2: i maybe forget to mention this(dk how important it is) but the trans will be behind RB25DET NEO(iam doing swap) It will be there for a little while. Iam planing to do bigbox or BMW tranny..
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
