  • Replies 62
Its well known that odometers are tampered with, which is why you should buy a car based on its condition, not how many k's it has. If you're buying a car from Japan, have someone like Iron Chef or Beer Baron organise a person to inspect it.
well I think in this case it's a pretty safe bet as to who wound it back.... whoever bought it at auction. and if that website is listing it as their stock then that would lead you to believe it's them.
to be honest though in the past it's usually been japanese sellers winding back odometers before sale to get a better grading, or the other half were done after being bought by an exporter/importer and wound back before ending up in whatever country they were going to.
it will happen much less now that japan records mileage at shaken intervals. so at basically every 3 years the kms are recorded on the rego. as the most recent buyer you get the rego/export certificate and you can see what kms it had at the last inspection. if the car now has less then you have a problem!
like priestly said though this is the reason why you need to inspect any car you want to buy (or have it inspected). people can and do lie in car descriptions. and kms is an easy one to fudge to make the car seem more attractive.
I discovered the ad for my car which had 112,000kms on it in Japan. Strangely when it appears in Canberra it has only 71,000kms on it. :D
But I bought it as it had no tears in any interior or bubbles in the dash etc, has never been smashed (literally), had modified parts on it (done in Japan) I wanted to do myself, plus some N1 gear, was used as a daily by the previous owner (not a thrasher) and was tight as a drum when driven. Whatever the speedo says becomes a mute point.
If you're buying from a dealer that has a freshly imported car on the lot, ask for the export certificate and/or the auction sheet - if they can't provide either or log books, walk away.
Funnily enough most of there cars are around 60KM to 80KM :(
Coincident.....i doubt it :D
you are right they all are around that
lets say you go ahead buy the car and you can prove that its been wound back, what can you do?
how about digital odo can they be done too?
Digital odometers are apparently just as easy to wind back...
Some online store advertise their kits as 'plug & play'
Not to sure what can be done after you've discovered its been wound back...besides using the courts and so on...
I will say that the V series car you can tell if they have been clocked. the speed pluse and odmeter do not work. (found this out the hard way after doing cruise on one and it had NO pulse at the cluster!)
Trust me, the V series can be done as easily as other models.
There are many cases that kms are changed for legitimate reasons in Japan. Sports cars often have their speedos changed to the 320km/h item and they will revert back to the old item when it comes time to sell the car. ie, lots of skyline owners opt for the nismo items. Also some cars have faulty speedos they a changed at some stage in the cars history. But you can usually trace the history with the shakken paperwork.
Edited by BigWillieStyles
Why be that bothered if the car is in really good condition? Yes 99.999999% of cars are probably wound back but how many Ks do you think realistically has been wound back? 100,000km? Highly unlikely. A more realistic figure would be round 50,000km or less. Throw that into the odometer reading you'll still be under 200,000km. Unless you're driving a rotar, I dont think it really matters all that much if the car is in a decent condition.
I saw the same thing. A car on Japan Auto Direct with 117,000kms on it and then for sale in Melbourne with 80,xxxkms. I won't mention who it was because they are a regular contributor to this section.
Was it the one on Ebay as I was emailed a few cars like that.
Edited by Guest
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
