Who's Winding Back The Odometers?
guys... seriously..
like
know a fence.
but you're all retarded. ;)
no seriously
when you purchase and import a car - what are you importing? what are you purchasing?
are you importing and purchasing a CAR??? or are you importing and purchasing a bunch of paperwork n statistics?
trick question. you're getting a CAR
if your R33 has done 120,000km and shows 56xxx on the dash
do you love it less? does it not drive the same? does it not shine the same after a nice wash? does it not make you say OH WAOW. when you floor it??
it's STILL the same car you imported. it's still the same car you bought... so who cares?
no realy. who cares.
keep a car maintained n serviced and it'll pay you back in enjoyment. i mean OBVIOUSLY there is some instances which are ridiculous ie 340xxx km wound back to 47, but aside from that... who cares
helps your resale cos dipsh1ts want those "low km" cars anyway
  • Replies 62
Exactly. It's the same sum of parts you bought. I'm not fussed, personally. More bothered with other things.
Point remains. Those doing it are dishonest pieces of garbage. It gives a bad rep to imports.
yes. and it's pretty obvious who IS doing it... that is - people who have the most to gain from their own selfish trickery and greed
which is pretty obvious if you have half a brain... but... if you're willing to buy a car from of these irresponsible i****t u**d c*r y***s that do this sort of mischeif without performing necessary checks ie: making your own assumptions and guesses and asking to view previous documentation thennnnnn you kinda... need to learn yourself i suppose
so ... to finally CLARIFY and make it REALLY simple...
the REAL person who's winding back the odometers....
...is...
your mum.
and she does it because you're adopted.
Edited by Mr Eps
 Share
    • Ultimately, if the tip is not far into the runner and the o-ring seals, then you are in business. Have you applied pressure to it as is? It is not really a problem for the injector to twist once it is bolted down, the oring seals it and you don't want it jambed into the oring too hard The plenum is intended to take multiple size lower injectors with different adapters, but the way you have it is fine if they seal.
    • Are these the Dmax ones you are in reference too? https://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35#description Not a bad idea to get the uni flange ones. I have sent just jap an email too. Will see what they say lmao. Only thing is the Dmax ones are on a big back order. Low key anything will be better then my OEM ones I got as they are sounding like popcorn when I go under load lmao 😂☠️🪦.
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
