Have a slipping clutch in a standard R32GTR. Planning to replace with a heavy duty single plate next week - (for future 300 RWKW/circuit work).
Was also going to get a larger/extended etc sump installed in the new year.
Question: Is it more economical to get them installed at the same time? Can the sump be installed with only the removal of the gearbox? or does the engine have to come out? Also, which aftermarket sump is recommended? Tomei? Trust? (extension?) (baffeled?)
Where to purchase in WA?
Cheers
https://www.sau.com.au/forums/topic/301143-r32-sump-install-questions/
I believe the baffled Trust extension is what most people use, needs to be welded in.
Sump off (especially in 4wd) is pretty much an engine out job. You might be able to save some labour if the box needs to come out too.
Most people use the Trust Sump extension with baffles (needs to be welded on standard sump)
Cheaper option is a Tomei sump baffle for the stock sump
otherwise you can go for custom setups like Hi-Octane or something
as for installation i have no idea :D
Trust extension is SHIT ..
Want this bad boy set up .. Oil change it takes 9ltrs
This is whats on our 32 , done by Advan performance in NSW .. Look at 3rd pic you see blue earls fitting . That is now plumbed from Advan catch can to sump with earls 1 way oil valve
trust sump extension and baffle kit is very good and good value for money
only problem you may have is it sits lower that xmember, but if you have decent suspension it does not matter... my car was low and i never had a issue with it touching the ground
i have the imports 101 kit, i was going to get the trust one but didnt like how low they hang.. very happy with the imports 101 kit and good service too
think it was about $1100 supplied and welded to the standard sump
i think my greddy cost around $500 welded to the standard sump and ready to go...
double the price is a bit steep
Pics of how your sump sits ???
Thanks for replies so far - but can the sump be extended/replaced with the above mentioned products/extensions without removing the engine or gearbox? or can it just be done removing the gearbox?
(As mentioned previously, have to replace clutch, so will also modify/replace sump if it can be done with just the gearbox out).
If can be done without removing either - happy days..........I will get it done later, and just replace the clutch now.
(nothing more frustrating then having a GTR with a slipping clutch!)
Cheers
I have removed the Sump without removing the engine but its not really any easier than removing the engine. Stock pump is ok with bigger sump but the pump is a weak link.
Imports/Garage101 have a billet Oil pump gearset upgrade now.
Thanks.
So - according to above, gearbox removal is irrelevent to sump replacment/modification?
  • 3 weeks later...
just an update on this.
im gonna get a N1 oil pump for my BNR32 and was wondering what is recommnded for a Sump Extension
Trust?
Tomei? etc...
what brand and where can I source one from either QLD or NSW? for a good price
Cheers
Looks much the same as the Advan one, Very much more complex than the more basic Trust sump inc the trick Baffles.
There is a Cylinder head drain option also.
sorry havent got any pics of how it sits, but its pretty much exactly the same as that advan one.. the rear head drain is a standard fitting on the sump - 10 i think. i had no intention of using a rear head drain so i have it plugged up.
comparing this to the trust extension is not fair.. these are a work of art once fitted and and sitting behind the kframe in a nice safe place is where the extra $350 is, not to mention the extra oil they hold compared to the trust jobby
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
