yeah mate thats what they came off, havent got pics but mayb able to sort something out. looking at 2700 for the turbo and manifold, open to any suggestions as well. cheers Matt
https://www.sau.com.au/forums/topic/30121-assorted-bits/#findComment-613375
  • 1 month later...
looking at only 1200 for the lot?? not sure on the wastegates. The manifold is back down at JMS you can give them a buzz to find out the size 0882606919
Also got the sub zero style plennum as well. If you have HPI issue 35 you can see it in there on my car. looking at 600 for that
https://www.sau.com.au/forums/topic/30121-assorted-bits/#findComment-658139
yeah, mate still got the engine and head? the engine has been re-built with standard stuff and the head is of atm. what are you after?
Actually wondering if you still have the old motor not the new one. However want one with the head. Dont need any plenums or turbos and stuff. Just something to stick in the shed and start pulling down myself for a rebuild.
https://www.sau.com.au/forums/topic/30121-assorted-bits/#findComment-658151
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
