if ur car plays the music at full belt and it stays on then ur fine
see how long it stays on without starting the engine
see how badly the headlights dim when the bass hits when ur engine is idle and ur lights r turned on.
ppl get newer batteries (better batteries) to prevent those things really... its the alternators job to keep the current levels up when the cars moving.
As long as the battery is in good condition I doubt very much you'll need another one.
The first step of upgrading cars electrical system is usually the alternator as the battery is just the storage device remember... doesn't matter how big it is, if the alternator cannot keep it topped up it will still go flat eventually. :D
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
