Looking For A Better Isp
Factory Dash Lamps...Half the speedo was dark...T10 3 Watt Park Lamps...T10 5 Watt Tachometer Chip/IC...Tach would randomly go crazy or stop, replacing capacitors and re-soldering the chip would work for a week or so but it would always fail again...AN8352UBK (Buy on ebay AU) Heater/Air Con Control Button Lamps...Grain of Wheat Bulb 12V...Tried LED's they fail after a month or so(even with current limiting resistors)
Hi, need help on wiring i swap motor from rb25de neo to S1 rb25det. Is it possible i can still use the de neo loom or do i need the s1 loom? Can i add extra wiring to add wastegate soleniod and iat sensor? Can i use injector and coils on same loom as i running bosch injectors and vag coils? I bought nz wiring trigger kit for neo, can i use that on s1 motor? What else do i need to do to work everything right?
