Hey guys, ive just bought my auto s1 r33 gtst pretty happy with the performance
and handling. But theres an issue with the top radiator hose being compressed
after driving. Is this an issue or is it normal? I normally have to top it up with about
250ml of water. any info or help would be greatly appreciated.
Thanks
https://www.sau.com.au/forums/topic/301310-radiator-issues-help/
if it is compressing once the car cools then it sounds like your cap isn't doing it's job properly, or there is a blockage in the hose that runs to the resevouir, or gunk at the bottom of the resevouir that is blocking the hole when it tries to suck coolant back in.
  • 1 month later...
yeah replaced it with a genuine nissan one now its not compressed, great. but i still
have to top it up with about 250 ml of coolant! damn i dont know where its leaking
from ive checked under the car while its running cant see anything. Could it be
leaking into my engine? man that would make me pissed.
replace radiator cap sounds like its not operating properly should be a cheap fix
didnt help when my top radiator hose was leaking coolant, when i was replacing the hose
i noticed the inlet was a bit corroded and have a brown residue. Why is this? I flushed the radiator
put new coolant hope this helps my engine.
Edited by UFC33
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
    • FYP. Sadly. Even bolt cutters wouldn't take 2 sec. But in the days of 18v angle grinders, nothing is safe.
    • One piece driveshaft I would recommend a dual CV setup otherwise stick to OEM. I have heard most one piece driveshafts cause excess vibration otherwise. The transmission grind I'm quite familiar with. You can try shockproof gear oil, otherwise you need a new transmission. The shifter is extremely simple on these cars. If you want pull apart the assembly and replace the plastic bushing but I doubt that fixes anything. The tail light issue is very common, unfortunately new tail lights are long discontinued. The trunk antenna going up always is because your radio doesn't have a true power antenna control, just remote amp power signal. There is a blank switch plate that you can pop out and install a switch for this or alternatively source a head unit that has proper antenna control. Throttle body sticking you have to disambiguate by disconnecting the cable and seeing if the linkages are the problem or something else. There is a procedure to adjust them, refreshing them is also somewhat involved if that's the issue. I have dealt with many of these issues. Old cars really are fractals of problems. The more you fix the more you discover there is to fix.
    • Welp, you've got a long list of experiences right there. I'd say you're on the right path.
    • That's correct, suits my requirements a bit better. Sure there are also numpties there, however it's generally a different vibe and more my kind of vibe.
