Hi there,
Normally for a problem like this, i'd goto my mechanic, but with Xmas break and all, thats gonna be a bit difficult, so hoping some1 can help me with this.
To cut a long story short, I've just replaced the oil filter housing piece on my rb25DET. After screwing it all in, putting the oil pressure sender back on, refilling the oil, took it for a test drive and everything was a-ok.
Then today, I started it and noticed the oil pressure gauge sitting on 0 and the oil warning light on. Checked undeaneath the car, no leaks, checks the oil level which was fine and engine also sounds fine.
So im thinking the oil pressure sensor clip has come loose, so i take it for a small drive. To my horror, the oil pressure starts moving up VERY slowly, ie doesnt make it to 2kpa.
Now i know low oil pressure can be a sign of engine failure or a failed pump but im thinking its too much of a coincedence that Ive just changed the oil filter housing. My first thoughts are that something is blocking or interfering with the oil pressure sender. Was wondering what other ppl think it might be, Thanks.
Also FYI, I installed a new adapter onto the housing that lets me put 2 senders in it, and installed a oil temp sender in the other hole - its a gold t-pies looking thing.
Also the new housing I installed was 2nd hand, I gave it a quick clean with the cloth but im worried that there might have been some large piece of gunk inside it that I couldnt see and is now blocking oil access to the sender.
Edited by Taso84
check the wiring on the sender, sounds like it could be a poor connection on something, i had a similar issue with my ground wire before i ground off the paint off the chassis to make a better contact.
low oil pressure causes serious damage, very quickly, so if the motor's still strong after 5 or so mins of running, you can rule out oil system failure i reckon...
If the factory oil pressure gage AND the idiot red light came on, you have a real problem, not a wiring problem. The red light is a seperate sensor that's just and on/off pressure switch and it's completely independent of the normal gage.
should still make its way into the engine, the only way out is to the main gallery,
if you can open the oil cap while its running and see if there is oil splashing around in there, if not then its a problem.
so, you replaced the oil filter/cooler assembly? why?
no aftermarket oil cooler with hoses? do you now have a remote oil filter? if the hoses are mixed up that can trick the sensor.
Hi guys, and thansk for ur feedback.
Just to answer some questions, no i did not renew the oring on the housing shaft, so im not sure whether it is there or not. If this were missing, what would be the consequences?
Also, no i dont have a oil cooler now, basically my old housing broke due to overtightening of a sandwich plate. T04GTR, when u say open up the oil cap why its running, u mean the cap from which u pour oil into right? I didnt realise u could see down there but ill check it out.
did you renew the oring on the housing shaft?
my guess is its either faulty or missing.
my thought too, if the old one was off for awhile it could be perished or missing.
Well obviously you dont understand the fact that oil pressure is crucial for the survival of the engine.
Just fix it and be done with it, or take it to someone who can!
You can drive it if you like but chances are you wont get very far.
RB25's hydro lifters would sound like 24 rocks in a tin can if they were not getting decent oil press,
Good chance you botched the install but as per most of the people here, rather get it sorted asap preferably by a pro, oil problems and engines = expencive.
It's been a while since i dug up in the 25 but isnt the oil pressure sender and the oil light unit that big round gold colored two pin thing by the oil filter?!?
If so if it has been damaged somehow when changing out the housing that will probably explain why the two readings went wacko at once.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
