TAKE OFF OIL FILTER HOUSING AND CHECK FOR BLOCKAGES
DOES THE OIL PREASURE RISE UNDER ACCELERATION?
no it doesnt really, just seemed to rise alit bit as the engine got hotter (prob as the oil got thinner and could bypass the blockage into the oil pressure gauge)
And to answer all the other question, yes i do understand the importance of oil pressure, but before u just blindly flame me, maybe have a closer read of wat ive asked. To clarify, i am wondering whether a blockage in the oil fliter housing/ damaged orings would be bad in the short term in terms of damage to the engine. The way i understand it (i could be wrong), if either these 2 are the problem there is still oil pressure in the engine, but the oil is just not getting to the pressure sender and hence not displaying on the gauge. I realise if its blocked, the oil is not getting filtered properly and over the long run this is bad.
I also did abit of research and apparently some ppl have had the same symptoms and found out it was a faulty oil filter. I didnt buy a ryco this time as i normally do, but i dont really see how a faulty oil filter could cause this problem.
Thanks for the help guys so far, good to be able to discuss this on a public forum... Ill keep this updated as i go just in case any1 else stumbles onto a similar situation.
ok, to save everyone your headache. take to mechanic or do it youself. borrow or buy a aftermarket oil pressure gauge.(not autometer or any one that uses olives on nylon tubing)
the thread on the block/engine is 1/8 npt.
install it, and check. ps..every car really needs one. factory is shit.
my car didnt have a factory gauge yet the factory light saved my engine from grenading really big time.
my oil pump cracked (33gtr pump with a crank collar on a 30det) and the oil light picked up the pressure drop before the tuner noticed any noise through his knock headphones. we got it shut off etc before there are even any marks on the bearings.
will be installing one now however. what brands are best?
Edited by SirRacer
my drag car uses a fuel and ignition cut out system should oil pressure fall below 30psi with an override switch for start-up. Its already saved 1 engine due to an oil pump failure on launch (N1 oil pumps don't like banging off the limiter with ignition cut at 9500rpm)
did you renew the oring on the housing shaft?
my guess is its either faulty or missing.
Is this the housing shaft you are referring too???
Pic is my old motor which as far as I can tell never had an o ring on there?
there is a ring on the end which could seat an o-ring an one almost flush with the block which could maybe as well
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
