For the head unit you can only use the constant and ignition wires from the standard loom, as the speakers have common ground. I ran my amp power cable through the a/c drain grommet.
hmm looks like im going to pay for it get installed seems 2 much for a 1st timer to handle lol
https://www.sau.com.au/forums/topic/301351-installers/#findComment-5004566
Actually it's pretty easy. Grab a test lamp/multimeter and look for the constant +12V and ACC (const will have 12V always and IGN/ACC will give you 12V when you turn your key to ACC). Umm I think it's yellow for acc/ign and red for constant, can't remember but your radio will have labels/diagrams.
You have to run the speaker wires, the antenna wire will plug straight in.
https://www.sau.com.au/forums/topic/301351-installers/#findComment-5005515
it aint too hard, just get a soldering iron to secure the headunit wires
but if you have additional wires left on your new headunit, just leave them be
I stuffed up my antenna when I plugged in the additional wire
https://www.sau.com.au/forums/topic/301351-installers/#findComment-5006133
